10
Everything posted by ivans imports
Why do you guys love the EJ22? Confused...
ivans imports replied to nobangmycar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Interferance motors make me lots of money so I like them ! customers not so mutch or best of both worlds 2.5 with 2.2 heads -
Get a wildlife camera motion actavated cheap way to see whats going on whenyou are not home pics never lie
surfaced heads ? had a set yesterday had been surfaced with orbital grinder had badly been cleaned and dident seal had only 3000kms on them and leaking badly how was the block on the lower fire ring on #3 and #4 cly ? if anealed to badly will not seal well. is it posibble just low on coolant or air traped in coolant sestem
Adjusted idle down now CEL
ivans imports replied to yblocker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Never addjust hard stop tells ecu that you have ft on gas when you do not will lose idle contact switch if mess with hard stop idle is addjusted by screw behind idle motor from side of TB -
are you shure car hot after fans have cycled rev to 3500-4500 let off and watch for bubbles in overflow tank any ? no next step new radcap mabe thermostat but if car has more than 200000kms on it and heads have not been done then very good chance headgaskets are going. Or pluged rad or seizing waterpump stuck thermostat but most likly headgasket
Functional Restoration 77 wagon 4x4 250,000 Mi
ivans imports replied to subaruguru's topic in Members Rides
Love the how to keep your subaru alive book thinking about making a new 95 and up book like that -
Troubleshooting Backup Lights
ivans imports replied to alaskaloyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Heres a cheat the senser on trans wears the end down pull senser and remove the aluminum washer reinstall this will move senser slightly closer to trans giving it a new range to turn on have fixed many non working reverse lights this way -
Non interferance engine whats not to like no bendy valves and good hp reliably have seen stock 91 ej 2.2 with 550000kms on it never been apart -
No Horn/Hazards/Clock- Blows Fuse. Ea81
ivans imports replied to Skylar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The plug for the horn rubbs on the body and shorts the horn is + powerd all the time wire shorts blows fuse 95% shure shorted horn check all horn wire harness on front of car have fought this many times.Check were wire harness comes thru body -
4 differnt heads 80-82 extra two bolts on bottom side small valves. The 82-84 nohydro small valves no bolts on bottom 83-88 large valves from chaser no bottom bolts. And the 83-85 ea81 T with injector holes and big valves no bottom bolts theese ones were bad for cracking and geting cooked. I do have some of all of these heads but geting rarer
Have been having same type problems when pia bulbs installed and any higher end bulbs dont seem to hold up But the stock plane jane bulbs seem to last forever. Have also noticed that the headlight bulbs nowdays are super cheaply made and most china produced i think the elements they use is substandard and dosent last. Have had 40 or more subarus with burning out headlights problem. Worse on 99 and up cars
sorry thought you were restoring it no worrys
Check ground on coil braket were it is mounted on body the braket must be grounded to give spark and it likes to rust and loose its conection and drops out spark and injector pluse add extra ground wire from coil braket to - termanal on batt and see if that helps very commen problem., Have a ecu from a 89 turbo ea82 mpi wagon is canada model might interchange
