10
Everything posted by ivans imports
Did this swap over last cupple weeks 2.2 from 92 turbo legacy and high low five speed from gl in my 98 outback sport. Took some doing but works well. Had to upgrade to outback injectors and change xross members. have been driving it for a week now is very fast. And I have 2wd and low range loving the 2wd mode
Replaced valve seats is big red flag this is almost impossible without subarus tooling just went thru this with airplane ea81 the valve seats had burned under the sides of them causeing them to drop out and smash valves. The cam being out one tooth would cause this to did you line up the chamfered hole on crank with dot on cam ? could also be decking the heads and block messed with valve geometry but doubt it
'82 BRAT is hurt, hurt real bad.
ivans imports replied to newsalempride's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Put TBI on it or ea 82 carb- 11 replies
- carburetor
- intake
(and 1 more)
Tagged with:
The carb is iceing fix heat riser been there- 11 replies
- carburetor
- intake
(and 1 more)
Tagged with:
Been able to save two 2.2 s with head retorque both were 300000km + and both were pushing bubbles into overflow the one got a turn on all 12 bolts other only could move 8 but both stopped blowing bubbles in over flow and have seen 10000+ kms since no bubbles and no problems. This only works for slight leaks if badly gone will not help
subaru brat suspention
ivans imports replied to ScoobyBrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what parts ? gl wagon from 81- 84 same have some front end parts -
Use your 2.2 short block with the 2.5 cly heads this works well have done many some mods to 2.2 headgasket needed and timing belt tentioner needed but makes a good little engine in long run. Is some of these I built with well over 150000 kms on them. Then your intake and wire harness lines up and fits you may even not have check engine light on
ea82 cooling system confusion
ivans imports replied to jkinz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I do retorque on ea82s when do a used engine install no problems yet and most of the time there are loose ones is worth doing but time consuming. My money is on plugged rad / headgaskets take the air out by cracking the thermo housing bolts and let bubbles flow out -
New Boxer Pistons To Triple Output
ivans imports replied to MR_Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thinking inside the boxer lol -
Intake gaskets... I know I know...
ivans imports replied to Subaru_dude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well loyale ran them till 94 so still some time left but old brat parts getting very hard to find my caliper rebuild kits took 3 months to get from Subaru but did get them -
4x140 to 5x100 bolt pattern adapters
ivans imports replied to matts87glsedan's topic in Products for your Subaru
The rear tires were very close to rear sus mount had to trim the edge smooth and use a 5/16 spacer to clear but fits well and looks good got a test drive in no shakes wobbles worked well. Except for now the old ea61 has to work a lot harder to turn those big wheels -
Intake is one piece engine is 4 pieces -
'78 Brat - Charging/Not Charging
ivans imports replied to CMJAnew's topic in Historic Subaru Forum: 50's thru 70's
On mine the brushes wore down and were not contacting well was really easy to change them -
The Subaru ones are grafite coated steel others are just cardboard and as the engine heats and cools the expanding and contracting will tear them apart. The Subaru ones are ment to let the intake move -
putt 16s from outback on my 80 brat yesterday few bugs but all worked. back was really tight to rear sus some grinding needed -
How the hell did this happen?
ivans imports replied to shoebee2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
At last count had 35 subarus here from 77-03
