10
Everything posted by ivans imports
Anyone swapped an EA81 into a '78?
ivans imports replied to petey's topic in Historic Subaru Forum: 50's thru 70's
Yes i have ea81 into 78 wagon i used the 4 speed deul range took some shifter mods strut brace mods clutch cable carb hoses mounts worked rad works drive shaft works overall the car performed way better and had high low. Took me about 3 days work but i had whole engine and runing gear to work with. Also had my 81 brat with factory ea81 in old body to compare factory install to mine worked good -
Is the green test mode timing conectors unpluged also the black single wire ones unpluged if its still pluged in timing will not be right
Need help with 1980 subaru brat ej22 swap
ivans imports replied to skinny664521903's topic in Subaru Retrofitting
91-94 2.2 stay away from interferance ones after 96 -
ea hi/lo trans in my 97 legacy wagon 2.2?
ivans imports replied to nerpel's topic in Subaru Retrofitting
I have addaptors the my freind regan made ej to deul range he may have more hes on my freinds list -
A pump from vw cis eg rabbit or ealy jetta or volvo mecedes or vw efi van all use remote hp feul pumps look for CIS car in particular as they needed high feul preshure to run I run a vw cis pump on my car way biger and meaner than subaru one
The maff dosent open it weighs the air coming in by how fast it moves bad maff no idle no revup flooding ect lacking power not a maff thing timing ? feul delivery ? leaks after maff on vacume sestem or timing diagnostic conector pluged in.
Now tuning time 1/12 weeks till next race time to set up the deul stage nos 50 to start and 120 at 3/4 mark on track hoping we can get some test passes in before next race and get a bitt better dialed in
clutch not declutching?
ivans imports replied to LPGsuperchargedBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Smart and cheap the subaru way ! -
Take off slave cly remove the piston clean around the bore with 600 grit snadpaper or hone lube with brake lube reassemble and reinstall drain syestem and use dot 4 fliud it has higher boiling point so works better on hot engine. have been finding the slave sticks half way back up and will not let fliud move into the slave. Have fixed 4 or more in last cupple months is mostly peadal sticking to floor problem
I most defanatly smoked the backside of crown / pinion and only did a 150 backwards pass mind you 300+ hp with nos and 31 paddle tires. It dident break just melted smeared and striped. I a'm still not a beliver of backwards runing diff
1996 Subaru Legacy station wagon(tons of pics)
ivans imports replied to soobie_newbie67's topic in Members Rides
Nice job !! I like the subaru wall tail light sweeeeet !! -
Back to turbo agian sounds good ready to tune for next race took 2 hours to change back not to bad at all
drop it on a frame or make your own subframe setup toyota diffs mabee transfer case then whynot 2 speed powerglide behind 2.2 with transfercase lightweight and buletproff next thing a'm working on is subaru to chev bell houseing addaptor 350 in subaru and 2 speed in subaru sounds good to me or rwd subaru with 4l60 or 4l80 gm trans or buggy with ls1 engine subaru trans take that yea old 4eat lol
Loyale making bad sounds...
ivans imports replied to MR_Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
whoops missed that then the springs inside the clutch disck are getting loose and rattling -
Drive shaft ujiont
