ivans imports
    10
Everything posted by ivans imports
  1. Also have seen the conection on the top of feul pump sender to pump burn and make bad conection at under side were pump harness conects whould get worse as it heats up
  2. Took my 80 brat to local car show no one had seen one in 10 years + round here rarest car at the show by far
  3. thank you North wet helped tons now i feel confedent to diagnose this car
  4. I do plugs wires and valve covers as a set no point if oils going to get on your new plugs and wires
  5. stop cleanig mafs make no differece just riuns them
  6. Piston slap is running to smooth for bad rod take out #4 #2 pistons knurll them and put them back in sound will be gone. But realy start with pulling the oil fillter and dumping it out into a pan tant you can see if any meatal or berring materail in the oil. Have heard worse piston slap than that always #2/4 that slap have you treid pulling the wire of on that cly and see if noise stops when not firing ?also a oil preshure check helps min 10 psi hot at idle. And oil light should go out in under 1 second cold start
  7. power feeds at fuse box or fusabble links loose ground on intake maf senser
  8. odb1 and has no green conector just multi conector with small jumper pins is a odd car 96 but no obd2 nowere to plug in scaner. Cant figure out how to get codes
  9. Sorry they are haveing site trubbles we are working on it and i lost matt for a week we are on it
  10. ok heres what you do roll the window down all the way take a light and look down to the lach on one side will be the lever to relase door other side is the lock. The outside door handle lever that gos to latch sticks down pull it up or mauanly push over the latch to right i use a 2ft long snapon flat screwdriver for this and patence
  11. Working on a 95 svx having a problem to read engine codes anyone have a printout of code read procedure on svx ? has a airbag light on two if anyone knows how to code check airbags whould help to thanks all
  12. i clocked the inside two teeth have had luck with a shim under the addjuster nut
  13. I have biult a cupple i use the 2wd legacy case with ea82 pushbutton guts in it works well should be same as what you want to do but dobut you could use the wrx awd and internals in it
  14. warning have done this caused to mucth load on bar and it broke they dont like to work well clocked like that broke two in a row
  15. have used toyota and nissan injectors before must have same ohms
  16. Has anyone tried adding a enrichment gasoline injector to a propane setup to add extra feul under load or boost can this be done. Like i do with my nos setup adding extra feul at same time as nos thru one commen injector
  17. I have at least 4 of those trannys all good just sitting around have no cars for them
  18. so this will drive a realy borad that drives curcits or the chip controls realys that are part of same board
