10
Everything posted by ivans imports
92 Loyale Won't Start After Sitting 2-Years
ivans imports replied to grotto's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Clean up grounds on coil bracket to firewall and add ground wire from - batt post to bottom coil bracket bolt then try -
"NOOB" looking to buy a BRAT!
ivans imports replied to buckkiller's topic in Meet n' Greet. Your USMB Welcome Center
Mine is stock have been trying to get collector plates for it -
Have a nice restored 80 brat very clean no rust 5000$ 100 % complete -
The VC changed in 96-97 years from a stacked clutchpack with plates and diff. To sealed VC that is unit design I have been fixing the late model ones by installing a early model one in place have to change the whole rear assembly of trans but get a better unit in the end. Jaming up when trying to backup is the snap ring on VC poped out getting between the teeth of the awd transfer gears. Makes a mess seen this many many times bad VC unit
And all in one sentence !!! the shims behind the bearing are key they are matched to trans unit and must be reused back lash can be checked buy Prushin blue or by feel. by holding both axle outputs and turning pinion to feel backlash. As long as no changes were made to side bearings is no need to move crown gear
Other cars/Vehicles we own
ivans imports replied to DJtheGOD's topic in Non Soob Cars and Bikes Discussion
Have a 79 chevy short Buss 410 hp built engine tows my race buggy and looks cool doing it { YES WE DID SHOWUP AT THE RACE IN THE SHROT BUS } pulling the short buggy -
Vacume leak exhaust leak idle to high timing to far advanced my 80 brat gives a pop when I shut it off. Vacume advance or mec advance sticking on idle should be 800-950. idle at 1300 with screw backed out sounds like vacume leak check hoses and intake gaskets
Heater core source?
ivans imports replied to Speedwagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I rebuild my own -
Have had a run of bad pinion bearings on 99-02 outbacks come in with trans whine in front diff two in one week noise gets louder the faster the car go's. When I got trans apart found the pinion bearing had lost the coating on some of the rollers and had damaged the race. Installed the new bearing from Subaru 195$ and 6.5 hours later fixed for under 1000$ customer was quoted 4700$ from dealer to fix this. Was some time involved to set crown and pinion backlash but was easy to check. Anyway wondering what that front diff noise is
Check cam belt timing or diss is one tooth off I have changed the cam gear in position involved but can be done is keyed onto the end of cam and presses off. Have seen many ruin this gear
Check the gear on end of cam for knife edging have seen many a ea82 running with diss out 180 and they used #4 as #1 to get it to run like that good old ea80eww
Transmission stub shaft swap - Who has done it?
ivans imports replied to Responsible Jon's topic in Subaru Retrofitting
Sorry note the pos of interlocks -
have done it many times is the last part you get to inside the trans and must be torn down to diff but diff dosent have to be removed just snap rings a 90 degree snapring plyers is important tool for this job. And extreme care must be taken to not pos of interlocks on shifting mec -
86 BRAT Fuel pump/Disty issue?
ivans imports replied to TIMBERTIGER's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You can remove top half of carb remove float and needle and undo seat is 10 mm or flat screw the screen is on the bottom of that you can cheat by removing the fuel line fitting and peek in with a good light and see if its pluged -
And a 2nd one came in bad pinion bearing two in a row 98 outback this one new pinion bearing is under 200$ so is worth fixing
- 47 replies
- Transmission
- first gear
(and 2 more)
Tagged with:
Find a hitachi dis for it Nippon ones not so good also have you checked the fuel pump timer ? and the screen in the carb on the neddle and seat was a problem on those carbed cars screen pluged up and bypassed carb = no fuel
