10
Everything posted by ivans imports
true but if your going to change it anyway is worth a look to see what happened
- 47 replies
- Transmission
- first gear
(and 2 more)
Tagged with:
strange issues and sad mistakes
ivans imports replied to daddydongo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Might have damaged the tps senser -
Band takes 25 min to change and same for forward clutch pack parts 150 $ is very first part in trans when center pump section is removed. Easy to inspect bit of a pain to remove diff and pinion but no big deal
- 47 replies
- Transmission
- first gear
(and 2 more)
Tagged with:
Dose the engine turn by hand ? if so try a small wire from + to small terminal on starter see if and thing happens this will bypass car make sure trans is in neutral -
I raised my impreza by using outback struts all way round had to change the rear control arm front mount plate that was all came up 2.5 inchs and can run a 15 tire now
starter contacts tap it with hammer while someone holds key in start pos -
Fluctuating oil pressure
ivans imports replied to Dinky26's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Oil pump is bullet proof might need some new orings -
Is fairly normal to be low at idle as long as it comes up when reved if worried put a manual gauge on it to check exact psi -
EA82, Valves keep get stuck open!
ivans imports replied to KristjanJohann's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Also had a justy with old gas do that but gas was really bad -
Sugar in the tank ? will do that
