10
Everything posted by ivans imports
swapping 1991 engine in justy 4wd ecvt
ivans imports replied to rhon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i will have to price out the berrings and seals and pull pan on thiss one make shure is standard berrings and is in good condition shiping is a bitt tough were are you how many kms from kelowna BC i will have a awnser for you on monday if thiss engine is good enuff or not -
over 80 of those motors i know it well and have seen many failed my justy engine has 12years on its 1rst rebiuld and i do oil pump gears every 75000kms as thiss was the weak link. When checking justy motor let it warm up till rads hot let it idle and listen any chain noise problem flickering oil light problem bottom end rattle problem and exhaust should sound even -
i live in a area with some realy steep hills and long hills i think the 4eats take a beating out here a'm fixing lots all the time but still not as many 4eats as i do busted 5 speeds. I rermove all inline fillters as they deleted it in 92 so they thought it was not needed i think it was a potato in the pipe.
Fuel issue and losing my mind.
ivans imports replied to Distraught's topic in Old Gen.: 80's GL/DL/XT/Loyales...
opps my bad as long as he gets the point -
Windshield Washer Fluid Pump
ivans imports replied to rdweninger's topic in Old Gen.: 80's GL/DL/XT/Loyales...
pull right front iner fender well down and will see pump they get ruined when they sitt over winter and freeze the impeller spins on the pump shaft and dosent turn i think all subarus use the same pump take one out of a legacy putt in there -
the tbi injectors wear to the lean side mabee injector is on its way out or cam timing +1 green diognostic conector thiss will hold the timing at 0 and not lett ecu addvance timing -
I'm 45min from kelowna bc on hyway 6 is funny had a justy come up needed a motor just last night no worrys have two good ones now. Are you confedent enuff to go thru the engine or whould you need me to do that I whould do mains rods oil pump rear main seal front crank seals timing cover waterpump timing belt cam seal addjust valves and valve cover gasket before i whould install any justy motor costs a bitt but then will last forever. -
Need to replace a 78 Brat engine
ivans imports replied to BLUPRNT's topic in Historic Subaru Forum: 50's thru 70's
Thats probly why i have so many old gen parts. Non of those cars left up here and to hard to get the parts down there dosent bother me at least i have some engines to work with if your absulotly stuck -
I bought it last night 120$ deliverd to my door seems to check out havent pulled the pan yet but rocked the crank no knocks i whold reseal and reberring it anyway as its very easy when engine is out and hard in position -
had a 05 outback turbo with the lowermost valvecover bolt broken on ps side what a job to fix that had to drop the whole front xmember to get a drill at it but valve cover was not to bad to pull
- 85 replies
there are some rubber plugs by ds feet for clutch and options have seen them removed for amp wireing and left out or hole check thiss or mabee ac drain hose is inside car insted of draining outside
- 9 replies
- forester
- floorboard
(and 2 more)
Tagged with:
80 Brat strut options / jump seats
ivans imports replied to vwBrat's topic in Historic Subaru Forum: 50's thru 70's
i have some used ones not to easy to find theese days -
Corosion in cylinder
ivans imports replied to the sucker king's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i probly have a good striped down block -
Justy motor came up for cheap on are local buy and sell will try and get it -
i use a mutsubishi 100 delta wound alt comes off 84-89 2.6 caravans was a realy heavy duty alt and has same plug as subaru used the feed wire for the choke to excite it has been on my 81 brat for 10 years no problems
