10
Everything posted by ivans imports
most spark plug ishues i see is from the spark tracking down the side of plug instead of down the center of plug the less resistance in the plug the longer it will last ngk V power all the way i do not like the platnum or iridium plugs at all even when they are called for i do not use them and { IF IT DONT SAY NGK THROW IT AWAY ]
i built 3 engines thiss week a 2.51 2.5d and a 2.2 and sadly the 2.2 is the first to sell because it gos for cheaper with more reliability the other two have cars sitting waiting for motors. The glue dosent even have time to dry and they are gone. I have been trying to rebuild two engines a week ontop of my regular subaru repair work and endless line of headgasket jobs. Any rebuilt subaru motor is valubble up here anyway there is way more dead engines than good ones
Vote on your favorite BRAT!
ivans imports replied to kingbobdole's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my vote is the 81 with gen 1 body but ea81 and high low trans and TBI -
Intake Manifold Bolts?
ivans imports replied to Dinky26's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i take a 8-1.25 die and clean the threads with that and be like new -
is youa gona catcha soma fishas or whata's hey i got your car to be 3ft taller just added snow lol
steering problem **need help**
ivans imports replied to Lfreck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
on my 79 brat the rag joint was catching on the gard for it and had torn away at the rag joint was shreaded but was able to buy it new from subaru the threads from it were tangled up around the shaft -
update the 03 test forester after 3 months of periumiun feul the 420 whent away came in for broken o2 wire but no more 420 the good gas fixed the problem but took at least 20000kms. And the scrap guys give me a 100$ each for used subaru catts the aftermarket ones they give me 5$. anyway have been beating up on peoples check engine lights all last week fixed two that had light on for 6 years or better one broken wire at rear by canister. And one broken wire above the gas tank having many problems with the emision wireing at rear of car.
Frankenmotor dyno results
ivans imports replied to presslab's topic in NA Fuel Injection Engine Tech
man i wish i had acsess to a dyno -
have fixed many svx trans and they never fail agian i change out the forward drum and clutchpack for the one from a 98 outback is larger and has better oil flow. and i overfill the front diff 1.8 L and increase the cooler return line port and ditch the trans preshure soliniod reistor that alows the tcu to modify preshure. And the lower gears putt less load on the trans and the higher stall gets the engine into its power range.
it gets better shops are stealing the factory subaru catts and replacing them with cheap chinese ones or none at all had 3 customers that had no idea there catts had been stolen. One they just riped out the o2 wireing and told them it whould be normal to have the check engine light on. Had a strait pipe and they had charged her hundreds of $ for stealing the catts. they probly got 200$ for the used catts as scrap.
check the top off strut tower mounts mabee seizeing up or tight ball joint or dry rack
