ivans imports
    10
Everything posted by ivans imports
  1. Dose the tach bounce when cranking ? This is my signal test for dis if all is working right the tach should move when cranking slightly try unhooking everything but The two wires from dis and the + power feed see if that gives it spark maybe tach is shorted or nosie supperser
  2. Have never seen a 3.0 need headgasket yet seen burnt valve and cracked block and broken pistons but that's it
  3. I do if you cant find them but would like to save them getting hard to find
  4. I run fenelic spacers on buggy made a big diff in intake temps
  5. Is the diss turning ? striped gear or broken shaft ? is it posibble coil is hooked up wrong ?
  6. They came on early dodge vans with cruise 73-80
  7. I think the highest one I have seen is 425000kms and still going Did you look at the guides when you took header off ?
  8. On mine the fan housing was warped just had to recenter fan and trim slightly under it the fan cage was touching the mounting plate just slightly enuff to make noise. or you have a mouse nest in it
  9. Takes me about 2.5 hours But 1rst change cabin air filter mabee its gross a heater core will have a sweet sugary smell to it and fog up window when driving or drip on floor also check that the air door is on fresh air not recyle air setting this can cause fog up good luck
  10. When I do stuff like that is critical you check that bolts do not bottom out in thread bore as this can cause cracks inside engine
  11. Use one from more modern car like a 01 legacy had better switchs that did same job
  12. The ex valve guides have droped have had many with this problem pull header look up port check the heights of valve guides the ones closest to the port are the worst. The one I just did yesterday had 4 out of 8 ex guides droped and they had broken bottoms of guides and would not let valves close. Misfireing poping rough idle lack of power. the local machine shop knurled and pressed in new guides and engine was fixed and ran 100% better
  13. Just found this in my 4x4 offroad mag Dakota digital speedo adaptors 1-800-852-3228 is for coverting electronic signal to cable signal this one was a ECD-100 these guys I bet would be able to help you
  14. About 4 hrs work intake harness and TB and idle motor has to be swaped over unless is exact year engine
  15. Well the 0-60 times in Canada are way faster lol 60 kms
