10
Everything posted by ivans imports
Need a Master Cylindar
ivans imports replied to djellum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
have had some loyales trap air in the rear porportioning valve at the back of car the rear takes a long time and lots of fluid to remove all the air 1/2 L or more. I whould still blame the rear brakes somwere. Addjuster upside down ? or stuck or air -
have some good clips but cant seem to upload any vidio onto here
MAF ground, cycling?
ivans imports replied to 86 Wonder Wedge's topic in Old Gen.: 80's GL/DL/XT/Loyales...
loyale spi ? have seen a bunch pound out the center of the injector pintle on thiss injector the more worn the LESS feul it moves there wierd like that mabee a new injector -
funny thought i mixed up a roller cam with a hydro cam one day and had the wrong cam to match the valve train thiss ran ok but not good was the wrong profile. when i put cams side by side was very different is it posibble somewere you had thiss kind of mixup ? it still ran well but was just never right. Took me a long time to find thiss once the motor was togther and running.
on thoose cars a low brake peadal is always related to the rear brake addjusters stuck or run out of travel or backwards very very rare to see bad master and very commen to see rear brake problems -
any way to check valve clerance i run into it with 2.5ds were the valves are to tight and sett misfire codes is it smooth hot at idle ? also have seen a cupple bad mafs latly but runs very ritch when bad or super lean. if your engine uses hydrolic lifters mabee one or two of the hlas is stuck in full out position have had thiss problem to. and last thing check your compretion no sense chasing a problem if it has a low hole good to at least know what you have. On the buggy race engine i comp test it before i run it so i have a base of what the comp was before i started is a good referance to chase problems
buggy is geting a facelift gets the 96 outback front clip to give it a body for race season super cut down and lightened. should look realy cool kinda like a micro machine subaru
same as addjusting 2.5 d take the head off is best way i built a tool to push the bucket down so i can slip the pucks out for 2.5 d . but the six I have no buckets for or shims so head whould have to be taken off. the dealer took thiss car back as the customer had just bought it from the dealer a month ago. sad part is they knew it had burnt valve when they sold it they were going to change the engine. After i located one for her kinda got burned on it but dident look like a nice motor job to do anyway.
i rebuilt a carb yesterday on a 86 gl std the antibackfire vacume line that comes off the egr valve was pluged with carbon and had colapsed in the air filletr box cleaned the line resealed the carb gaskets. Hooked up all the missing lines and worked very good. The timing had been cranked too far to try and get more power set that back to 8. The antibackfire curcit is a very critical part of the workings of the hitachi carbs and mingles with the exhaust syestem so it plugs easyaly most carb problems i see are from thiss curcut and lines being left off or put in wrong places the vacume diagram under the hood is the best info you will get .
the preshure at high rpms is erelavent what maters is how long it takes to get preshure exactly. and how mutch preshure when hot at idle min 10 psi hot at lowest idle if less than that berrings are on there way out. I time the oil light on the first start cold and see how long it takes a good engine takes 1/4 second a bad engine takes 1-2 seconds for light to go out and any knocking on startup is bad
Intake and wiring question
ivans imports replied to biggman100's topic in NA Fuel Injection Engine Tech
can use the 2.5 wire harness on 2.2 intake
