ivans imports
    10
Everything posted by ivans imports
  1. had a few with thiss problem lately was the belt slipping on ps pump just slightly when the groves get worn on belt will cause thiss change belt and try agian titening it dosent help.
  2. pull oil cap while running look for blowby smoke cracked ring land ? comp test and check ps valve cover vent for pluging
  3. iceing up ? no coolant flow thru T B or bad ground on coil boltup bracket bad coil wire. A feul fillter whould only do it when under heavy load uphills or long hyway accelerations. Or diss cap has a crbon track or rotor is arcing to center shaft of disstributor anything high tention whould be worse under load.
  4. i love the fact that i live in middle of nowere can run anything we whant in bush are propane subarus run off a brbq bottle in the back mabee not so dot aproved but simple. How far can a turbo justy go on a ten lb propane bottle will find out for you guys. When the bottle runs out turn on the efi and keep on trucken.
  5. Is there a vacume advance ? ruptured diafram have a bunch of ea82 disribs magic eye or magnetic pu ?
  6. have a 2001 3.0 outback was smashed in front but has very good rear suspention parts untouched yet
  7. We ran a 420 cid porpane mixer on a 2.2 turbo and on a 3.0 turbo and have run ea82 and ea81 turbos on propane seems that the 420 is just big enuff.We had tried to use a 325 mixer but was to small for ej motors worked good on smaller motors. I like to run both so can swich back and forth between propane and gas.
  8. my justy i put on a turbo legacy intergrated oil cooler and a sunbird turbo and header i love it in the snow. But even with the oil cooler i only get about 2500 kms before oil gets cooked turbo has no water cooling. So oil gets hot and needs to be changed more often
  9. Mines in a 79 wagon with remote pump but most cut down harness cars are slow to start first time when cold
  10. my cut down harness car is a pain to start the first time every time uses a 2.2 harness with 2.5 turbo engine have narrowed it down to air lock between injectors and pump when it sitts. It has to push all the air out before it gets feul to injectors thiss takes some cranking time. Could be fixed with a one way check valve close to injector feeds to prevent feul prehsure bleed back
  11. thiss whould be a rail type car long and high hp wonder if could get a mega squirt that could run 12 cly at same time ?
  12. What oil when its cold well my justy turns a bitt slow in - 25-35 but starts just fine and gets 15-40 all year round. Its the only car i whould drive in winter as it far surpasses the handleing of any other subaru i own or have seen in the snow and ice. All my other subarus start fine with heavy oil 15-40 all year round. I a'm more woried about breakdown of oil from heat than i a'm about damage from cold start
  13. low reverse clutch pack if you go realy easy on it in reverse should last a bitt
  14. was thinking two bolted back to back with two speed power glide behind it with ford 9 inch in rear and subaru in front
  15. have seen more overheated subaru engines probly than anyone else. And the oil is cooked in most and dosent matter what kind of oil. The oil dosent make the engine fail heat do's. Yes synthetic will take more heat but i have seen no proof it increses the life of engine. Less if anything because people think they can leave it longer between oil changes. The engines i tear apart that have run synthetic all there life are way dirtyer inside than the ones that ran conventanal oil. I use quaker 10 -40 or 15-40 deisel oil no 5-30 ever ! and 10 -30 very rarely subarus have always liked heavy oil if you whant it to last anyway. Had a outback wagon 2.5d 420000kms on origanal engine ran wallmart 10-30 its whole life and still runs good and engine was spotless inside mind you it leaked a litre a day but still runing strong.
  16. just bought 10 sets of starter contacts they go for 2$ a set and take ten minutes to change do this dayly
  17. well two 3.0 = 6.0 L close but need more have two svx 3.3 that whould make 6.6 L closer butt still not enuff. To catch a blown acohall hemi think he was 2700 hp last time i checked did 200 ft mud pitt in 2.1 seconds take me a while to get there.
  18. man do i whant thiss engine !! bad ! looks like a mud dragster engine to me
  19. i have a 91 fun justy 2dr i cut down a 98 out back roof rack and mounted it to the roof using the factory outback mounting plates. I also glued all the seams with winshield urathane and monofoamed all the spaces in the roof thiss made the roof very rigid and strong. I carry a 300lb boat on the roof no problem. Late model justy ????? have never heard of sutch a thing they stoped maken them here in 95 mine has a 1.2 turbo engine makes 120 hp
  20. oil is oil and any oil is better than no oil have seen subarus run anykind of oil and last forever run it low one time and done
  21. hmm or bolt two 3.0 back to back and make a 6.0 48 valve flat 12 oh it even sounds good might be a tadd heavy but whould sound sweet. And use one monster turbo for both engines
  22. I think the tbi whould pass air care better than a carb as it has a 02 senser and can fine tune the mixture my tbi brat runs way cleaner than my carbed brat by alot and realy wasent hard to convert. 81 brat with 91 tbi it just works so mutch better
  23. the fan gets its power from the big black and red wire off bottom of fuse box and thiss plug gets kicked alot may have broke the conector or pulled wire out
  24. the first check is do the hazards work ? they share the fuse with horn then fix the burnt fan realy under the ds side of dash then take the shift interlock realy box and resoider the ground on the chip board . and mabee a fan motor if you tap the motor with hammer and it restarts then needs a fan.
