10
Everything posted by ivans imports
Automatic Transmision HELP
ivans imports replied to taz ride's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I 'm sure I have one can look today have scraped 50 loyales over the years -
Check rear wire harness on back right corner of car has not broken the harness for tank vent valve likes to break there and replace 02 if any doubt 02 controls feul delivery. Had a 99 impreza set codes for tank level senser and tank temp senser changed 02 and code went away was weird linked somehow
- 14 replies
- Bad mileage
- 1999
(and 2 more)
Tagged with:
I do not like the ea71 pistons weak between the ring lands the ea82 piston is far stronger On the ea 81 engines I build for airplanes / hovercraft we used the ea82 pistons shaved block / heads worked very well the ea82 pistons are higher but dident have any clearance problems. Mind you I planed very little of block and heads. At any rate the ea82 pistons are 50 % stronger
EJ22 powered Rx7 ----> now working on EG33
ivans imports replied to mellow65's topic in Non Soob Cars and Bikes Discussion
Wow nice job !! very cool setup 3.3 is a good engine but heavy and cool. How hard was the trans to adapt ? looks good on a Subaru engine Thinken rwd loyale or outback -
NOS !
Bring on the leaks... uh oh?
ivans imports replied to 92_rugby_subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ea8ewww ! water pump /headgaskets -
I put 350 hp to them with 33 in paddle tires seem to hold up broke one in two years of racing
- 38 replies
- 1991loyale wagon
- axle
(and 2 more)
Tagged with:
I use 85-87 axles Gl10 from turbo 3 speed the 3 rib ones toughest they made
- 38 replies
- 1991loyale wagon
- axle
(and 2 more)
Tagged with:
Needed. Cv boots 78 DL WAGON
ivans imports replied to Mtbakeris's topic in Historic Subaru Forum: 50's thru 70's
have a whole 77 dl wagon a'm parting but can use axle boot from 99-01 outback is very similar size just bit tight on inside boot shaft size -
1980 brat Hitachi carb question
ivans imports replied to skinny664521903's topic in Old Gen.: 80's GL/DL/XT/Loyales...
holding top of carb the needle should stop flow when float is sitting level and strait I blow thru spigot while moving float to confirm flow and stop of flow also should be a sight line on float glass or exactly half way up float glass. To high will come out top to low will run lean
