Everything posted by ivans imports
Dead outback EJ25D Need help on swap info
ivans imports replied to Ricearu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmake shure they check the crank to see if its bent of the 6 i had turned 5 were bent and had to be straitend
P0400 EGR flow malfunction
ivans imports replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhad thiss twice thiss week its the plastic diafram egr controler valve above the egr has 3 lines on top and one on bottom the diafram ruptures and will not hold vacume suck on the bottom line if holds ok if leaks no good i think its from mostrue geting in and freezing in winter
EJ22 in 98 OBW Auto opinion
ivans imports replied to maugli's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe addvantage is that the heads match the intake and give better power out of the 2.2 was not the heads that were problem on the 2.5d was the bottom end
Brat seats
dont know she not home yet cheap i hope the last set that i got cost me 500$ with no frame or belts are very rare round theese parts
1988 GL Automatic tranny help
forward clutch pack smoked
Install issues - can i repack the front bearings with race already pressed in?
ivans imports replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfront wheel berring replacment 45 min make shure you support the back berring when pressing it toghter
1979 Subaru Brat 4x4 4spd ALL ORIGINAL
my 79 brat came with 3 spare tranys if need one
Cheap horsepower from 79 wagon
ea82 carb have one on a 77 wagon and it hauls rump roast was a bitt of modifying but way bigger carb
Holy Cow! ... Three in a DAY! ... (Burnt Ignition Module)
i have 6 of those nipon distributors outdated so just sitting some were very low miles i realy good condition
ivans imports replied to maugli's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi perfer the 2.2 with the 2.5d heads i like to keep the heads with car if at all posibble
ivans imports replied to Ricearu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2.2 crank works fine but will drasticaly lower comp from 200-145 will still run fine and last forever we call it a destroker motor and use them with turbo have not ran to many na but it will work as long as they are both phase one engines i have put the 2.5d heads on 2.2 i do that all the time works very well and lasts
Brat seats
Had a good brat day my next door neighbor found a set of brat seats with seatbelts at grage sale on weekend wicked !
need longer accelerator cable
Howcome no one puts tbi on theese ? i have it on my 81 brat ea81 it works very well and make way more power than stock
make your own use dirt bike control cables cut down you can get your own end and soilder them on they are way heavyer duty and easy to find
99OBW. Mysterious brake leak.
ivans imports replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrear drum ? wheel cly if not master leaking into booster not likly but posibble rusty line ?
'98 OBW EJ25D replaced HGs suspected fail - what now?
ivans imports replied to samneric's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXResurfaced a 1981 ea81 head yesterday and it had exact failure ponts and the newer head exactly the same places were low on head and gasket had been moveing vibrateing and had worn the head in lower oil return ports funny same problem from day one we have been debating weather a heat risistant spacer on exhaust whould help to keep exhuast heat away from headgasket.
Thermoswitch / Fan Wiring
The switch is not a ground switch on the ea82 cars only the ea81 cars the ea82 car its a power in power out switch it gets hot and makes the conection axoss the termanals
blown front diff
not on the awd end on the pinion end the nut that holds the two berrings in place berrings did not fail just came loose was very strange have never seen thiss one. Tranny had never been apart.
front differential drain plug - size?
ivans imports replied to lekmedm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX21 mm and new ones have a six point touqures
blown front diff
Came axross somting i havent seen yet the nut that holds the berrings on the pinion backed off alowing the pinion to go to deep into crown and interferd and smoked the pinion teeth right off. Have rebuilt many front diffs but have never seen thiss nut come loose see somting new evry day fixen subarus
ivans imports replied to samneric's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts a 2.5d oh tear it down surface block surface heads reberring and rering bottom end and put it back toghther and should be good make shure you use avinoic form agasket on headgasket surfaces. I have a customer car here today that customer did own headgaskets did not surface heads and i can see oil leaking from the bottom seam of headgaskets runs ok but leaks oil and ticks like crazy because lifters got mixed up anyway formagasket whould have saved thiss guy a oil leak for shure no worrys its not just you. Good thing its here for front diff so i can ignore engine problems. I whould tear your engine down and rebiuld it you will be happy with results and ask the machine shop to let you watch them plane it you may be suprised at what you see
Alignment dowels for block
ivans imports replied to anastij's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwitch ones where the heads go on ? or where the block halfs join ? i whould have both but i think you could use a cut down bolt or pipe aslong as its the right size
Brat seats
I did hear back from the DOT they said is good no problem they sugested not good for adult use but not ileagal the question whent right to head office and they had a discution on it anyway all good. Was bumed thogh my old brat was turned down for colector plates because it has some chips in paint and the front valance is missing some paint is bummer i did not what to repaint it i like its personality and patina
How to pull ignition lock cylinder?
ivans imports replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi use a reverse drill bitt to remove the headless screws
front end noise?
ivans imports replied to john40iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave been puting all awd subarus at 35 front and 32 rear to compansate for engine wheight so get no windup
