miazda
About miazda
- Birthday 07/20/1985
Location
Sandy, Oregon
Occupation
Small Business owner; marketing
Vehicles
10 forester, 04 fxt, 88RX
miazda's Achievements
Member (2/11)
0
Welcome I'm fairly new to the site, but also have an RX. Quirky is a way to describe them. Theres no aftermarket for the older subarus like there is for legacies and impreza's. Though I've had pretty good luck with a combination of dealership, autozone, and rockauto.com for most things. I don't know about the rear diff rebuild, if anything its probably the bearings in it. Which are available at least through rockauto. Post some pictures of what your working with
Lost the clip for clutch cable, pedal end
miazda replied to xman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
^yeah you gotta talk to the one older guy that's been there since who knows when. and have him dig through his book for the old part number, which does work in their system, but they often can't search that system directly. Good news they pretty good about supporting their cars, and being as common as it is likely not discontinued. If you're still having trouble let us know. I'm friends with my subaru parts guy, and can probably track it down. -
Front struts for 89 GL turbo 4wd wagon
miazda replied to methusalah's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I like rockauto.com -
Is it just a c-clip? ....hardware store Perhaps dealer order? -
Going to work on paint this weekend most likely. Well, at least getting some of the prep out of the way. I have a number of rusty areas to tackle first. I'm planning on painting it a different white than factory (toyota super white II, specifically). I had the paint, from an ae86 I was going to respray, but sold before I did so haha. I like it its very very white, as the name implies. I can't however find a paint code for the bumpers' gray color. http://www.indysworld.com/80s/general/paintchips/paintchips.html ^that chart doesn't specifically cover 88 Subaru, and I haven't been able to find a picture of it in the old color chip books. I'm guessing gull gray would be right? Only problem then is, there's 2 gull grays, with different codes correlating to different years?!?! Anyone ever painted their RX bumpers the factory color and have some input? I mean I could wing it, and originality isn't that important to me (not painting original white). But if anyone knows that would be great.
Drove it into work today, noise is still there. Now that its not pouring rain/snow I can hear it better. It gets better when the brakes are applied, and gets worse when going around corners. Guessing bad wheel bearings, and before the pads and rotors were worn enough to not hit. Oh well, more work to do I guess haha. Cheap RX isn't cheap? Who knew ?
what'd you have in mind?
Honestly after thinking about it, its such a slight thing I'm probably gonna do exactly that (clearance itself). I just can't figure out why it would even happen. I will definitely bleed the fluid though, it looks disgusting. As far as mushy pedal is concerned, I'm gonna guess if I want any kind of upgraded lines I'll have to have them made.
Baffles will have to wait. Developed another issue/question. Was replacing front pads and rotors last night, got them all back together feeling pretty good about the job on the whole. Went for a quick jaunt down the street, hear a speed related crunching noise. Noise not really affected by braking except for when I get to near stop. Brakes also don't feel especially great, despite not having opened the system. Also the e-brake is much tighter than previously, like 2 clicks maximum. But I suppose that should be how it is? Got it back to my shop and on the lift can't see anything out of the ordinary. I triple checked every bolt to make sure they were tight. Tried spinning both rotors with the wheels off, and I can turn it by hand (albeit with some effort) they spin as I would expect them too. Bolted the wheels back on so I could spin quicker, noticed the caliper is hitting the wheel in one spot as the wheel goes around. Right side more than the left but both are doing it. ....Ummm huh? I'm totally stumped, I've done lots of brake jobs but never seen this. Now mind you it's a pretty slight hit, and obviously it got better by the time I got back to the house (clearanced itself). Any thoughts? ....let it clearance itself? Also the brakes just don't feel exceptionally great, like I think they felt better before this job. Really puzzling.
Good to know, guess I'll see if they're clogged or jammed in some way tonight and report back.
Had surgery so work on the RX was postponed for a couple weeks. But I replaced that hood linkage, as GD said it's not too bad to do, lubed up the catch mechanism so as to hopefully not have any further issues. Unclogged the windshield squirters, I'm pretty sure those squirters have a "rally pedigree" all their own judging by the amount of dirt removed. But both are working great and no money spent replacing. Started on brakes but ended up with the wrong pads, gonna finish that tonight. Had a foglight question though. Did some searching around on the site and from what I can tell it isn't a fused circuit but has a relay somewhere under the dash. Any idea what that looks like, or is placed, or what to look for? I replaced a bulb, checked the connections down there, and cleaned up the ground on the hood release (was already there anyway). No worky-work. So, barring a break in a wire, that relay is suspect. Just don't wanna tear blindly into the dash is all. Also took another look at that rear window problem. The window seal (glue I'm guessing) is done at the top, and every time you close the door the air pressure created makes it "pop" up about 1/2-1". Ummm. Yeah. Guess I'll see if a glass company will reseal it? Dunno if theres an at-home remedy for something like that. Also, it seems that same air pressure makes the doors hard to get shut all the way, is there an air baffle somewhere on these old subarus? I know on most newer things its tucked in the back bumper area. Just wondering if this is a problem anyone has experienced, and after I get it resealed is this a recurring issue?
^thankfully I doubt anyone wants my ************box.... and to open it the first time I just reached around behind the bumper and tripped the lever by hand. Also, about the hoses, thats good advice. Thankfully I'm pretty diligent about noticing symptoms and have had that exact thing happen to me before (different car).
^good to hear that. Lol I was reading here some thread about heater hoses being replaced and thought "huh I should probably do that soon." Welp, the car said today was the day, on my way home from work. Didn't overheat, I felt the heat go cold and killed it quick. This is why you have AAA kids Haha.
So it diesels when you kill the ignition? Usually that's a result of timing in my experience with old carb'd engines.
If it grinds a bit going into first while rolling thats pretty typical of subaru 5 speeds. It's a rather old design. That being said the above advice on redline oil is pretty sound. Every subaru 5 speed I've driven has 1st gear hangups, it just comes with the territory.
