Everything posted by Brat78
I just put a new motor in our 94 legacy wagon, and it came up with CEL code 35, purge valve. I changed it out, ran this procedure to clear the code: I ended up running it down the road, and the CEL began to flash. I assumed it was the all clear signal. Well, now it won't stop flashing. I ran the stored and current code procedures, and all seems good. However, the CEL is still flashing constantly. Any suggestions? I currently have the battery disconnected to see if that will remedy the problem. My hope is that someone has encountered this issue.
Source for rear end hanger bar bushing-Brat
Brat78 replied to Brat78's topic in Historic Subaru Forum: 50's thru 70's
That one that you put on the 20 ton press is it. Thanks for the info! Do you remember where you got them? -
Oil light comes on at stop light
Brat78 replied to Sub78's topic in Historic Subaru Forum: 50's thru 70's
It's great when they get on the road. I spent about a year chasing parts and then about 6 months sorting out quirks. It's now my only car. -
Tonight my rear end dropped out of the brat. Both bushings in the rear end hanger bar failed and the whole assembly just dropped, leaving the nuts and washers still on the studs. I have it rigged for now with some iron plates at the bottom so the rear end can't fall off again. Is there a source for those bushings?
About to pull the motor out of our 94 legacy. I have the four bolts at the bell housing off, exhaust disconnected, and center motor mount nuts off(2). Will it pull out at this point? My concern is the motor mount studs. Do I need to free up the crossmember as well or pull it as is? Thanks in advance!
Peek in the Attic Subaru Brat build
Brat78 replied to doughildreth's topic in Historic Subaru Forum: 50's thru 70's
I wish I had known you were up in keene. I had to junk my 81 wagon not too long ago. It was in Bennington, over near Peterborough. I would have given it too you. Anyway, the brat looks great. I would love to check it out next fall when we go back home to visit. -
Arizona Find: 78' Subaru Wagon
Sweet! Any more videos? I have some of my brat on youtube. User name is ldeliguoriII -
Rockauto shows the water pump 96017(Bosch unit). I believe I used 1/4 inch ID fuel line on my brat.
Wow. I don't recall that body style even going that far into the 80's. It looks like a pretty nice car. I'd snatch it up if a hatch is what you want.
1988 Subaru Gl 10 Price
Brat78 replied to scoobywagon45's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I wouldn't touch an automatic. -
My brat is pretty dry. Junkyard motor, which sat on the shelf for about 25 years. I am running valvoline maxlife in it right now, which allegedly helps older seals do their job.
I threw a 1600 at my brat and didn't look back. It sounds like you need a running car. A conversion would take much more time and money. My other car for 10 years was also a 71 bus. I got a deal on a stunning 72 and decided to pass the 71 on. With 10 VW years on your resume, I would recommend finding a junkyard motor for the wagon for now and just put it in. My EA71 is so light that my wife helped me with the removal and install. You should have no trouble.
Alternator rebuild or use a Mod?
Brat78 replied to Dan-AZ's topic in Historic Subaru Forum: 50's thru 70's
I'd gamble on a set of brushes. -
Gen 1 Brat rattling gear shifter
Brat78 replied to maestro's topic in Historic Subaru Forum: 50's thru 70's
My brat is really noisy. I can't tell if it's the throw out bearing, worn sycros, wheel bearings, axles or whatever. But it's always been that way and never gets worse. It's a 35 year old Japanese tin can. -
I was going to rebuild my EA71 but one head was bad and sourcing a good one proved impossible. A lot of people had them lying around but I had no guarantee that I wouldn't end up with another bad head. I considered swaps but in the end for practicallity went with a junk yard shelf EA71 complete for $500 with a 90 day warranty. That was going to be cheaper than my rebuild in parts alone. Add labor into that and I am really far ahead. And now I have a reliable driver. Down the road I'll probably go EJ, but that'll be another time.
Stuck wrench
Brat78 replied to mattslote's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That looks as awesome as busting a stud flush with the case. -
We have a 94 legacy 2.2 with an idling issue. Cold start- On a first start up in the morning it will idle up fine and progressively drop idle as the vehicle warms up. Kosher. Warm start- If I take it to the store or where ever, on the second or subsequent start up, the idle will jump up to 1800-2000 rpms, and will stay there. If you drive the car a bit and come to a stop, if given 20 seconds or so the idle will slowly come back down to normal. It will usually stay down at that point, but not always. Sometimes if given some gas it will get stuck back up there again. If another restart is involved in the trip, it will most likely happen again. I have been unable to find a similar problem described online. Any help is appreciated. Cheers
ADVICE NEEDED re: flywheel/TDC position
Brat78 replied to NickNakorn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
WTF:eek: -
The problem I ran into with mine was sourcing the passenger side head when it was deemed unusable by the head shop. For me it turned out to be less expensive to get a junkyard shelf motor for $500 than rebuild mine if you include labor time. Way less hours to install. Unless, of course, you just want to rebuild it. My camshaft was chewed up also. And the cam gear is NLA. I figured I'd be better off with more parts around. I think next time around it'll be EJ time anyway. Same with the VW camper.
