JohnVT
Location
Hinesburg
Biography
backyard mechanic, keeping 2-3 old Saabs running, and one 97 OBW that belongs to my father-in-law
JohnVT's Achievements
Advanced Member (3/11)
10
Good deal?
JohnVT replied to edvanp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Replace the timing belt tensioner right away if it wasn't done with the belt change. -
The ignition coil I purchased from an aftermarket auto parts store has the same manufacturer and part number as the original that was on the car, and seems to be working fine. I had problems with aftermarket spark plug wires and spark plugs - use Subaru OEM wires from the dealer (also some online sources, search these fora) and NGK spark plugs. Good luck.
Hi - will check fuel, ignition, compression after the snowstorm tomorrow... (didn't get to do that yet, 2 feet of snow to clean up) If I have to pull valves, does anyone know a good machine shop in the Burlington, Vermont area? How much to machine heads, valves, replace valves?? can someone point me to a good procedure to check, change valves, and while I'm there, probably the headgaskets... OR if I decide to have this done, how much to replace valves, what else needs to be done. Has new t-belt, sprockets, water pump, oil seals, ... What should that cost?? Any experience to share with mechanics in this part of Vermont?? 97OBW 2.5 DOHC - EJ25 thanks
ok, how do I check the compression with no start? I have a compression guage, but I think it needs to be running? what do I need? I thought it was turning ok, so changed everything ($$$$$$$) as I described before, but now still whining when trying to start, and no ignition. but did sound like a backfire, so now of course, sounds like a bad valve. so is this a pull it out? guess I'll pull the HG too now... and the ECU has been complaining about the rear O2 sensor for a while too... hope that didn't mask something else. thanks.
Too much oil?
JohnVT replied to mtbe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Right - ALWAYS check the oil immediately after an oil change. It's just as likely to have no oil as too much. A friend lost an engine at a 'fast-lube' joint with no oil. Shop blamed it on the auto fill mechanism. He eventually got something out of them, but it was painful.
