Daskuppler
11
Everything posted by Daskuppler
Hello Everyone, I've got a '99 Impreza 2.2 5mt and a fried ECM. Are these interchangeable as long as it is for a 2.2? Is there anything special I need to look for when finding a replacement? Does anyone know where to find one? Is there any programming or other special concerns when replacing it? Cheers!
So about a year a go, I replaced the main ground contact on the block under the air box. It was green, no copper insight. I cut it back to fresh copper, put a new end on it, and called it good. At the same time, I replaced the battery with a new AGM. I had no further issues until today. The radio started flickering again. I also noticed that my key no longer stays in the ignition when the car is running. It's old and this isn't my only car with this "issue". My question is, could this be an issue in the ignition switch since the dash/radio/clock all flicker periodically? I guess I'll continue chasing grounds down...Any other suggestions?
Hello Everyone, I have a 2002 Impreza TS with some leaky front lower rear control arm bushings (the oil/grease filled ones). They've been leaking for a while and are starting to get some play in them so it's time to replace them. The stealership said they are $190 each. The auto parts stores don't carry them, unless it is Napa. Napa wants $120 each. I also have a used pair of complete control arms with bushings for $60 per side. Mileage is unknown. Reportedly in good condition. They are at a dedicated Subaru recycler. Rock auto sells the delphi ones for about $35. Are the Delphi ones worth buying? Would it be between to just get new control arms with new bushings? Thanks for any input!
Hello Everyone, I'm looking to install some Diode Dynamic SS3 Pro lights on a 2014 Forester Premium. My understanding is that the car is prewired for the lights, but some additional equipment is required. All of the other threads I've found have links to directions and parts kits but the links are all broken. The Diode Dynamic pods come with an adapter for the harness, Do I need a relay for this circuit, or is it already installed? Is there a factory switch, or do I need one as well? can I modify the corner inserts where the lights go, or do I need to purchase the XT inserts? I already have a light bar and would like to limit the amount of switches on the dash. Can I install the 2014 Forester XT column switch for fog light control, or do I need to add the auxiliary switch next to the traction control switch? Thanks!
I read a few reviews of people stating they were somewhat unstable at speeds over 80mph.This makes sense given the lack of a center rib, but it's hard to say how accurate it is. I was previously running the Continental True Contact Tour AS. It was my 3rd set. Michelin is certainly well known for making a quality tire. They seem to be geared towards relaxed drivers with safety in mind first. I saw a lot of reviews stating the CC2 understeers a lot, which I;m not a huge fan of. The car is already way too biased to understeer. Road tests also show problems with the tire changing direction in emergency maneuvers. The first turn is fine, but the second is very slow to respond. I ended up going with the Continental CrossContact LX25. The snow traction is a little less, but the Continental Warranty Department said they have only one complaint on the tire and that it should hold up relatively well on gravel roads. The LX25 is an improvement over the TrueContact with a new rendition of the tread compound, and added features to enhance snow traction. It also outperformed the original Cross Climate in snow traction so I'm happy with that as an all season. We'll see how things go. With my mileage warranty and some sweet talking with the manager, I was out the door for just under $700. Michelin was hesitant to say the CC2 could be used on gravel roads, but said it should do okay with light and infrequent use. If you're not familiar with the Continental, here is a link for reference: https://continentaltire.com/tires/crosscontact-lx25
Hello Everyone, I have a 2014 Forester and have been happy with my tire choice lately, but I only got 26,000 miles out of the current set of Continental True Contacts. The tire shop recommended an all weather tire, specifically the Michellin Climate Cross 2. They said they see on average 60,000 miles out of a set which is fine. My concern is the softer tread compound not handling dirt roads and/or light offroading very well. I swear I read somewhere that they chunk easily on anything but pavement. Anyone have any experience with these or other tires in the same class?
I'll check it the CS wiring, it was likely unplugged when I did the head gaskets a while ago, maybe it didn't get quite plugged in. The battery is good, it's a red top Optima and only a few years old. I'll check the grounds, hopefully it's something that simple. I've not had an issue since, not even the radio which was pretty consistent beforehand.
Hello Everyone! The problem child is a 2002 Impreza TS with 145k on it. Over the last week or so, my radio has been acting weird, I assumed it was failing since it's 10+ years old. The volume would randomly dip to 0, then back to 10, turn off, restart, sometimes even staying off, etc Today, while on a drive through the mountains and coasting down a hill at about 70mph, the check engine light comes on, radio starts acting up, then the ABS light comes on and the tachometer goes to 0...all other gauges were working including power steering and brakes. Hitting the accelerator did nothing. I pushed in the clutch, gave it some gas, and RPMs went up, then fell to 0 again. During this time, the CEL was flashing (though not like the severe misfire flashing). Flashing and the radio volume were in sync with clicking relays on the passenger side (sounded like it was in the kick panel, but I'm not certain). ABS light goes off about 2 miles later, radio returns to normal operation and the car drives fine for another 70 miles. Next long descent and all symptoms return. I took the next exit, restarted the car and it never happened again (another 200 miles until I got home). I later noticed that the clock on the dash had reset like it lost power (the time would indicate that it happened during the first instance. CEL turned off on the way home. When I got home, I had two codes: P0335 (stored) crank shaft position sensor A circuit ABS 22: FR wheel speed sensor. I went to scan again and the ABS module won't scan, and my code reader keeps disconnecting after displaying the p0355. No work has been done in the last 4,000 miles and the car drove fine after the restart. Thoughts?
Rust Repair and Mitigation
Daskuppler replied to Daskuppler's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for the information! I would assume I can pull the headliner and get to the roof ones, but you never know. If i can just sand the rust out and it doesn't create a hole, doI need to do much else besides prime and paint? Where's the best place to source paint? -
Hello Everyone! My question is not in regard to a Subaru, but I'm having trouble finding quality feedback from other groups and I trust the members here so I'm hoping someone has some insight. I have a 2006 Nissan Xterra and the paint is just crap. I recently noticed little spots of rust popping up through the paint, even where there is no damage. Is there anyway to mitigate this without cutting it out, welding in a new piece of metal, and repainting? I'm not really interested in letting the vehicle fall apart or getting rid of it, but I can't justify a 6-10k bill to have a body shop fix it. I'm handy with tools, have a professional grade HVLP gun/system, angle grinders, die grinders, etc..but welding is not.my strong suit, especially on gauged metal. Any help is greatly appreciated! All of my of my pictures are too large to upload, but I'll work on getting them downsized.
