Daskuppler
10
Everything posted by Daskuppler
Having had a third block put in after the second one spun the number two rod bearing and the main bearings seized, the car feels sluggish and like it has increased parasitic drag. Is this normal? The car slows down quite a lot when letting off the accelerator and seems slow to accelerate even at full load with no cargo and only one occupant. Should we be concerned...again? At time of failure on the previous block, the bearing failed while passing on the interstate, the red oil pressure light came on and the engine turned off while the car was moving. The dealership put about 300 miles on the car before returning it to us. The oil has a slight gray color to it at this time, but there is no metallic shimmer. The oil is already starting to get a dark golden color after less than 400 miles.
I'll look into the linked company above. As for dealing with SOA, this car has a rather extensive history at the dealership and on SOA's plate. They have been downright refusing to help in any way whatsoever. I have called multiple times, been to two different dealerships, had TWO engine blocks fail within 300 miles of install and oil consumption. We got the finger on the oil consumption during the test and after when it was burning 1qt every 300 miles. After getting two bad blocks, Subaru refused to provide any information on batch numbers, manufacture dates, etc. They simply shipped one from a different warehouse and told us to pound sand. I've spoken with the dealership manager and service manager where the work was done and we purchased the car. I was able to get a whopping $50ish off the seat bottom through the dealership and SOA couldn't care less. Not impressed. When this whole series of events started, I thought GeneralDisorder was pessimistic and should work on vehicles other than Subarus. At this time, I think he was being kind and generous with his "compliments" to Subaru. Sorry for the rant, it's been a bad 3 months with the car.
The dealership told me it was the occupant detection sensor and that they best they could do on the part was $690. is it possible to just short the terminals so it always thinks there is a passenger? I don't care if it goes off when no one is in the seat, I just want it to go off but don't want to spend $700 if I don't have too. The junkyards are pretty void of these cars around here.
Usually it's a short in the wire somewhere. Check for pinch points inside the door (window mechanisms, hinges, etc. It could also be behind the head unit if it's tight back there. You could meter the wire to confirm. The speaker could also be bad, check resistance while the meter is out. You could also just run a new wire in about 20 minutes and probably call it good.
- 1 reply
- 1
If it needs refrigerant, there's definitely a leak somewhere, usually it's the o rings at the compressor. I have a 2002 Impreza that had some AC problems; I would get cold air from the middle two dash vents and the side vents were warmer air. I did a lot of troubleshooting and replaced the condenser, high and low pressure lines, and expansion valve. While it was apart, I flushed the evaporator, and cleaned the fins (they were filthy (apparently the car has never had a cabin air filter installed). After all of this, my AC started short cycling. In the end, I think the main problem was the compressor which was replaced and everything has been fine since. Some notes and things I learned: If you replace the compressor pay close attention to the warranty requirements, everything has to be on the same receipt for most manufacturers. If your system is completely dead, or you have replaced the gaskets, pull a vacuum on the system for about an hour then shut the pump off and leave it connected for 45 minutes or so, this will ensure most contaminants are out of the system and that you have no leaks. You can rent the tools from most of your friendly auto parts stores. When you recharge, R134a pressure and temperature are almost equal, thus a charge of 34ish psi means that your temperatures are approximately 34 degrees Fahrenheit. If you are undercharged, that reading on the gauge will be below 32 and your evaporator will freeze up, higher and it does not cool. My AC system works amazing after the repairs, but it can be a nightmare especially if the system has had a leak or has been opened for an extended period of time. Contaminants left in the system will destroy a new compressor if you replace it. Good luck! AC work sucks, but it is actually pretty simple once you get your bearings.
Okay. Thank you. It stopped putting power out to the wheels despite the engine reving so I suspect something worse has happened...then the red oil light and it turned itself off. We will see. Mother Subaru has not responded yet and the dealership is still "finding room to do the tear down". One more failed engine and it should fall under Lemon Law.
I requested that a different team/tech handle it this time. The service manager reached out to Subaru for authorization to replace everything (heads, block, etc) with a brand new assembly. We will see. The oil was filled with metal and it just revved, but had no power output...then the red oil light came on and it died. Now we're here. I agree, once is a fluke, a second time is a bad tech. I asked for an FB25D but they refused to do that. This has all be a giant disappointment in Subaru. Hopefully it doesn't take them 5 weeks to replace it this time. The original block lasted 115k, but burned oil from the day we got it. It was at 1qt per tank of gas by the time it was replaced.
Only concern is metal circulating from the failed bearing, rod damage, and crank shaft damage. The heads have 115k on them, the block has 300 miles. I was hoping to get remanufactured heads out of the blown engine. They haven't pulled the heads or timing of so they have not been inspected yet. Can these be checked without removing the block? Say I wanted to have a third party look at them
