Daskuppler
11
Everything posted by Daskuppler
I have one of the caps with a lever on top to release pressure. I'll get an OEM style one just in case. The old gasket was paper, it was also an auto parts store water pump. The new pump is Subaru and a metal gasket. The new pump is in, I had to re-tap 4 of 6 holes and install heli-coils. They kept stripping out as I torqued them to 9 ft-lbs. I don't understand why they stripped but they did. For the record, I'm using Snap-On's aircraft grade torque wrenches so I know I wasn't over torquing.
Hello Everyone, I have a 2002 Impreza TS MT with 137k on it. Head Gaskets were last done about 60k ago. The water pump, radiator hose, thermostat, and all associated gaskets were replaced at that time. The water pump never sealed very well and has a slow drop from the gasket, not the weep hole. I recently replaced the radiator cap (maybe 10k ago). The car has never overheated and the temperature gauge sits right about where it should when warm, maybe ever so slightly biased towards cold. I turned the heat on the other day and it was barely warm. I picked up a bottle of coolant and poured about 1/3 of the bottle straight into the radiator with it uphill from the heater core. The heat came back, I figured it was just low from the slow perpetual leak I never got around to fixing. The car does not burn excessive oil (maybe 1/2 qt low at time of oil change. There is no indication that the car is burning coolant, but it is hard to tell when driving. I do not smell anything sweet in the exhaust, but that's not a surefire diagnosis. A couple days later, heat is gone again. I add a little bit more coolant but it doesn't help. I drive the car a little later and the heat is fine. I have noticed the radiator hose is quite hard to the touch when the car is hot. If I release the pressure on the radiator cap, the overflow reservoir bubbles. Is this all caused by the leak letting air in? Bad water pump? Bad thermostat? Dreaded head gaskets? Cheers, Andrew
Looks like I pay have located a bypass for this system. at about 10 minutes into the video, the presenter shows his drawing and sets it up with success at the end. I do not have the resistors so I will have to find some and give this a try. I ordered a bunch of resistors from Amazon, they will be here Tuesday so I'll give it a shot. The logic int he video is sound though.
If it's just starting to make noise, you're probably fine. I have an 02 and I smoked the input shaft bearing. I drove probably 10k on it before the debris in the gear oil started to grind the synchros down enough to where I had to hold it in gear. I still drove another 600 miles home. It never failed on me. Changing the oil won't hurt anything. I wouldn't add anything to the gear oil, transmissions are sensitive. Just buy quality gear oil (Subaru, Amsoil, or Motul) I replaced my transmission myself, it's a pretty easy job once the exhaust is off. It's just a pain, the transmission is heavy and getting the splines to align can be a pain. $300 is cheap for a transmission, but if you threw it in you would get more money out of the car....a bad transmission will certainly lower the sale price more than $500-600 dollars.
I did a little research in the occupant detection sensor at it doesn't look like it's as simple as a short or not in the sensor. It looks like it operates of of capacitance and the presence of a human more than just weight alone. Until I can confirm how it really works, I'm hesitant to just short the circuit...I would hate to blow the ECU or deploy the airbags or something stupid. SOA was unwilling to divulge any information but I suspect the bearing manufacturer had a bad batch since the failure was always due to a bad bearing. Subaru did shut down any shipments on engines from the first warehouse where the first two blocks came from. Hopefully no one else falls victim to it.
It does have the CVT. The engine never seized and the car never stopped rolling, in fact it was pushed to a safe spot but there is concern that there collateral damage. We ahve been assured that everything is fine and the only damage was in the block...every time despite the oil being full of metal. At time of failure, the engine would rev up but there was very little power output despite high RPMS. The red oil light came on and it shut off shortly after. I initially attributed this to the seized main bearings causing excessive drag on the engine causing the ECU to increase RPMS to maintain power output/speed. I question it at this point. I can scan for TCU codes when my wife gets back to the house, I suspect they have lceared any codes that may have been present though.
Having had a third block put in after the second one spun the number two rod bearing and the main bearings seized, the car feels sluggish and like it has increased parasitic drag. Is this normal? The car slows down quite a lot when letting off the accelerator and seems slow to accelerate even at full load with no cargo and only one occupant. Should we be concerned...again? At time of failure on the previous block, the bearing failed while passing on the interstate, the red oil pressure light came on and the engine turned off while the car was moving. The dealership put about 300 miles on the car before returning it to us. The oil has a slight gray color to it at this time, but there is no metallic shimmer. The oil is already starting to get a dark golden color after less than 400 miles.
I'll look into the linked company above. As for dealing with SOA, this car has a rather extensive history at the dealership and on SOA's plate. They have been downright refusing to help in any way whatsoever. I have called multiple times, been to two different dealerships, had TWO engine blocks fail within 300 miles of install and oil consumption. We got the finger on the oil consumption during the test and after when it was burning 1qt every 300 miles. After getting two bad blocks, Subaru refused to provide any information on batch numbers, manufacture dates, etc. They simply shipped one from a different warehouse and told us to pound sand. I've spoken with the dealership manager and service manager where the work was done and we purchased the car. I was able to get a whopping $50ish off the seat bottom through the dealership and SOA couldn't care less. Not impressed. When this whole series of events started, I thought GeneralDisorder was pessimistic and should work on vehicles other than Subarus. At this time, I think he was being kind and generous with his "compliments" to Subaru. Sorry for the rant, it's been a bad 3 months with the car.
The dealership told me it was the occupant detection sensor and that they best they could do on the part was $690. is it possible to just short the terminals so it always thinks there is a passenger? I don't care if it goes off when no one is in the seat, I just want it to go off but don't want to spend $700 if I don't have too. The junkyards are pretty void of these cars around here.
Usually it's a short in the wire somewhere. Check for pinch points inside the door (window mechanisms, hinges, etc. It could also be behind the head unit if it's tight back there. You could meter the wire to confirm. The speaker could also be bad, check resistance while the meter is out. You could also just run a new wire in about 20 minutes and probably call it good.
- 1 reply
- 1
If it needs refrigerant, there's definitely a leak somewhere, usually it's the o rings at the compressor. I have a 2002 Impreza that had some AC problems; I would get cold air from the middle two dash vents and the side vents were warmer air. I did a lot of troubleshooting and replaced the condenser, high and low pressure lines, and expansion valve. While it was apart, I flushed the evaporator, and cleaned the fins (they were filthy (apparently the car has never had a cabin air filter installed). After all of this, my AC started short cycling. In the end, I think the main problem was the compressor which was replaced and everything has been fine since. Some notes and things I learned: If you replace the compressor pay close attention to the warranty requirements, everything has to be on the same receipt for most manufacturers. If your system is completely dead, or you have replaced the gaskets, pull a vacuum on the system for about an hour then shut the pump off and leave it connected for 45 minutes or so, this will ensure most contaminants are out of the system and that you have no leaks. You can rent the tools from most of your friendly auto parts stores. When you recharge, R134a pressure and temperature are almost equal, thus a charge of 34ish psi means that your temperatures are approximately 34 degrees Fahrenheit. If you are undercharged, that reading on the gauge will be below 32 and your evaporator will freeze up, higher and it does not cool. My AC system works amazing after the repairs, but it can be a nightmare especially if the system has had a leak or has been opened for an extended period of time. Contaminants left in the system will destroy a new compressor if you replace it. Good luck! AC work sucks, but it is actually pretty simple once you get your bearings.
Okay. Thank you. It stopped putting power out to the wheels despite the engine reving so I suspect something worse has happened...then the red oil light and it turned itself off. We will see. Mother Subaru has not responded yet and the dealership is still "finding room to do the tear down". One more failed engine and it should fall under Lemon Law.
I requested that a different team/tech handle it this time. The service manager reached out to Subaru for authorization to replace everything (heads, block, etc) with a brand new assembly. We will see. The oil was filled with metal and it just revved, but had no power output...then the red oil light came on and it died. Now we're here. I agree, once is a fluke, a second time is a bad tech. I asked for an FB25D but they refused to do that. This has all be a giant disappointment in Subaru. Hopefully it doesn't take them 5 weeks to replace it this time. The original block lasted 115k, but burned oil from the day we got it. It was at 1qt per tank of gas by the time it was replaced.
