Daskuppler
11
Everything posted by Daskuppler
I requested that a different team/tech handle it this time. The service manager reached out to Subaru for authorization to replace everything (heads, block, etc) with a brand new assembly. We will see. The oil was filled with metal and it just revved, but had no power output...then the red oil light came on and it died. Now we're here. I agree, once is a fluke, a second time is a bad tech. I asked for an FB25D but they refused to do that. This has all be a giant disappointment in Subaru. Hopefully it doesn't take them 5 weeks to replace it this time. The original block lasted 115k, but burned oil from the day we got it. It was at 1qt per tank of gas by the time it was replaced.
Only concern is metal circulating from the failed bearing, rod damage, and crank shaft damage. The heads have 115k on them, the block has 300 miles. I was hoping to get remanufactured heads out of the blown engine. They haven't pulled the heads or timing of so they have not been inspected yet. Can these be checked without removing the block? Say I wanted to have a third party look at them
Hello Everyone, Any idea if this bad bearing is enough to have damaged my heads? Started making noise at about 5000rpms, drive for a couple miles before it was safe to pull over. Quite loud when running and the engine had almost no power. Block has 300 miles on it and is under warranty. The stealership doesn't want to acknowledge the heads at all. 20220818_.3gp
Subaru axles are green. They should have a hard boot on them, not neoprene (unless they have been rebuilt. Take photos of yours before you go so you can recognize them. Also, for the older cars, sometimes the dealers will have rebuilt OEM axles. They are cheaper and of the same quality. You can also have a shop near you rebuild them for less and the quality is usually pretty good. You will also need a punch to remove the roll pin, otherwise it will never come off.
It kinda sounds.like bad CV joints. The inners won't click on tightt turns like the outters do, but they will cause a bad vibration under load. If it is slowly leaking grease, it may be bad. They don't usually get worse as things warm up though. Parts store CV axles suck though so this can be an expensive repair with Subaru parts.
Yeah, it's kind of a catch all code. It's rarely catalytic converter though. It's possible the overfilling on the oil threw the code as well. That's a lot of extra oil and I would be imagine you were burning quite a lot of oil which could throw the low efficiency code. Maybe clear the code at your local auto parts store or disconnect the battery and see if no it comes back.
For me this code was my head gaskets. The code was thrown when excessive coolant was being burned. New had gaskets, code gone. Hasn't come back. Do you have any other symptoms? How do your spark plugs look? Is the top radiator hose hard after driving? car hard to start? low coolant? Loss of heat? Erratic temperatures on the coolant temperature gauge?
I think you should change your handle to General Disappointment haha! On a more relevant note, I agree with what the others said. Subaru turbos are generally unreliable. If you can do it yourself, great, but parts are definitely getting hard to find and the quality is worse now than when the car was made
That makes sense. They reused a lot of parts including the sprockets and timing chain. The parts list was really only the block and gaskets. Hopefully there is enough collateral damage this go around to to replace pretty much everything. After 300 miles, the oil was shimmery. Still golden, but shimmery.
Yes, it's at the dealership. They will be tearing it down again. They told us it's now unlimited mileage for 36 months. Who knows though. It is indeed a dealer remanufactured block. New blocks and new heads are apparently unavailable. Why do these have such a high failure rate? It seems like remanufacturing a block would be a relatively simple process when done in a factory.
