Daskuppler
11
Everything posted by Daskuppler
Hello Everyone, I have to do a drain and fill on my 14 Forester CVT. I had a dedicated fluid pump for this but accidentally used it for ATF on another vehicle. If I were to use it again on the CVT and pumped a few pumps of CVT through to flush the ATF, would the residual ATF cause any damage? I would think it would be so diluted it wouldn't matter, but I know these things can be sensitive. Cheers
The engineers get blamed for a lot of design issues, but we forget that they are constrained primarily by budget. Subaru tells them to build a car for x amount so they do it. Some things just cannot be accessible for a reasonable cost. I've also owned Subarus for well over 10 years now and never had to replace a relay on any of the cars. Everything is a trade-off and is largely based on likelihood of failure and service. The relays could be made easy to access at the sacrifice of your interior lighting fuse., Or headlights, etc. Have you tried working on a Jeep? Nissan? Toyota? Ford? Us Subaru guys actually have it pretty easy. At least our cars are.pretty reliable and easy to work on.
Hello Everyone! The car in question is a 14 Forester Premium. The issue at hand is some unwanted play in the bracket attaching the seat back to the seat bottom. It is only on the inboard side and started after the seat was leaned on. I pulled the seat thinking maybe something was loose since I am just replaced the bottom, but all was tight. I noticed that the square peg in the middle of the spring on this bracket was moving a in when I pushed on the seat back which results in the audible pop and movement. Two questions: One: Any chance this can be serviced? I didn't see any way to do so but thought I would ask. Two: Can I buy a new bracket only? Subaru was confused as to what I was asking for but thought it was probably part of the seat back assembly. I was not able to locate the party online but I'm not the best with their system. I have attached a picture from the Subaru parts website showing the part I am inquiring about. Cheers!
Hello Everyone! Anyone else flying through windshields these days? I get a new.one every couple months. The tiniest of chips turn into large cracks before they can be fixed. Pretty much any small rock blows the glass out and requires replacement. If it can be filled, it never "disappears" anymore, I can always see it. I'm tired of garbage products and service. What happened to the world? Why does everything just suck anymore? Why does a windshield cost $600 anymore and fail on pretty much the first impact? It's exhausting Rant over.
Hello Everyone, This is not on a Subaru. I have a friend who drives a 2007 Suzuki SX4. While driving, he noticed a loud noise, flashing CEL, etc. I went over and took a look at it and found the coil pack blown apart, the terminal was blown out of the spark plug and sitting in the spark plug tube along with some coil pieces, the spark plug was loose and no longer threaded into the head, and the ground was cracked and smashed into the electrode. Once all of the pieces were removed from the spark plug tube, I removed the spark plug and saw that only the first couple threads were damaged (looked like maybe it was cross threaded and only turned a couple times). I saw no scarring on the piston head and no real sign of impact on the spark plug ground except for the fact that it was bent. There was also no thread material from the head on the spark plug and the threads on the head looked to be in good shape. I didn't have a tap with me to verify. There is no metallic sound when the car is running and the CEL was cylinder misfire 2, engine lean, and catalyst efficiency BS. All associated to the missing spark plug. My assumption is that the previous owner was an idiot and cross threaded the spark plug and it eventually gave up and was damaged from bouncing around. Could something else be going on? Or is this a simple fix of new plugs, boots and a coil pack?
If you have questions, let me know. It was.all.pretty straightforward. I was no able to get it out without discharging the AC system. Make sure.you have something handy to hold the steering column up, you don't want to pull the firewall grommet out. Also, the airbag module has to be removed and is a toex head. I'm not sure what size it is, I just used vice grips in the head since I didn't have the right size. The bolts aren't in super tight. If you don't have trim/panel tools, get some.
Is the radiator cap new and OEM? Maybe it's not quite holding pressure, gets hot, seals and cools back down? I had a similar issue with a bad water pump gasket though my issue impacted my cabin heat more than anything. Engine temp did fluctuate a little bit. Best I could tell is system was sealed when everything was expanded and then would suck air in when it cooled down. I didn't really have much of a coolant leak so I never had to add coolant.
It won't hurt anything by adding it but could have catastrophic impacts if the gas goes bad. I keep it in my motorcycle, old truck, and all my other small engines just in case. Shelf life of gasoline is generally 3-6 months. I use Seafoam. It's cheap and has worked fine. My truck sat for almost a year and started right up and ran just fine.
Hello everyone, If you have seen my threads lately, you know I'm hard on plastic. I've been trying to track down a clock bezel.for a 2002 Impreza. OEM was $105 without the clock which was discontinued. Ebay was about $90 for dirty and stained looking items, but they had a clock...then there was shipping. I hit up Google and found a delightful place by the name of Subie Recycler Inc. These guys had one in stock, in like new condition with a working clock for $25. They are local (for me) in Wheat Ridge, Colorado so I was able to pick it up. They had a surprisingly large warehouse with nothing but Subaru parts and great prices. Don't ask them for a '14 Forester seat though. They have almost nothing from that generation. Good people. Good prices. And they ship most parts nationwide. Inventory is available online or you can call/text. I have no affiliation with these guys, just a happy customer who is rarely happy with the service I receive these days.
I finally got around to replacing the heater box. 7 hours later, everything seems fine. My heat is hotter than it was before and the AC is nice and cold. I did end up breaking the trim piece that holds the clock...Anyone know where I could pick one up? Ebay has them for about $90 including the clock (my clock doesn't work so that may not be a bad option). Anyone on here have a parts vehicle to sell from? I have a black dash.
The strut controls camber and this is really the only alignment spec you would be messing with. As long as you put both bolts in, the car is still drive able to the shop for an alignment. Good luck getting it all taken care of. A quality wheel bearing should last a long time so it shouldn't have to be done again. Make sure you do them in pairs unless there was an incident that caused an isolated failure.
OEM for most things, after market parts just suck anymore. Clutch you can run Exedy from the supplier of your choice. Have your flywheel resurfaced or just replace it. I doubt the engine has to come out to do this job, I didn't have to on my 2002. I'm not familiar with the 97 though. I would also suggest flushing the clutch fluid, brake fluid, power steering fluid, and radiator. Did the car sit with gas in it? Was it stabilized? If not, drain the tank and flush the lines before starting the car. Fluids and such you can buy at an auto parts store or Wal-Mart. If you're in a state that Rock Auto will ship to they are usually a reliable source, just pay attention to the grade you are buying. Post questions when you know what parts you actually need.
From my research, it seems.like a drain and fill is the recommended procedure and even what the dealership frequently does. It sounds like a special machine is required to flush the CVT and the wrong one will ruin it. Most failures seem to be the valve body, but who knows if that's a design thing or fluid related. I doubt it's fluid related as failures are all over the board mileage wise and it doesn't seem to be tied to poor maintenance. But again, there's not much official documentation. These things seem to run pretty clean since there's not many clutches, but they do still need a change and Subaru recommends every 30k for severe duty, which is pretty much daily driving if you live in a city. They don't specify if that's a drain and fill it flush though. Logic would say that draining 4.5 qts out of 13 and putting 4.5qts of fresh fluid back in leaves you with 13 qts of slightly less dirty fluid, but still dirty. Seems like you would have to do 4 or 5 drain and fills to have decent fluid again, which is a waste of fluid and time if it could just be flushed. I find these cars very frustrating with the lack of information. It seems like everything was just out together with the hopes that they were right, but the engineers don't really know how it works or why it fails...which is just ludicrous. Maybe this is all because they don't want people working in them at home...
