fud24682000
About fud24682000
- Birthday 12/10/1936
Location
Vacaville
Interests
auto repair, gardening
Occupation
retired prison staff
Vehicles
1987 DL wagon
fud24682000's Achievements
Advanced Member (3/11)
10
Thanks, maestro. Yes, too bad, it looks like you're down near the border with North Carolina and I guess it'sabout 26-2700 miles from here. I have not used JB weld before. I don't know if it would be strong enough to hold if I drilled the hole out. I think the guy who tried to fix it was going to use an easy out but he couldn't drill into the bolt with the drill he had. Glad to hear it's non-interference ... Ray Mac
NickNakorn, Thanks, I would like to repair it but it's not that simple. Apparently the tensioner bolt on the driver's side broke off flush with the block when the pulley bearing seized. My kin had an amateur mechanic try to extract the rest of the bolt, but he only managed to muck things up further, so there it sits. Possibly I can get it towed to a neighbour's property while I try to sort things out. I really don't want to scrap it, but I have a time limit to deal with as well. The other concern would be about internal damage when the belt on that side came loose; I don't know if if this is an interference engine. Ray Mac
Hi, I'm executor of an estate where this wagon was left behind. It will be scrapped by the buyer of the property but I can pull a few parts if I want. It quit running when the timing belt tensioner sheared off and the owner was unable to get it fixed (it's in a remote area). I can't pull anything big, or that would take a lot of effort to pull. Any parts I get I would sell, I would have no use for them. Starter? Alternator? Ignition parts? etc Would appreciate suggestions, thanks. Ray Mac.
Fan removal, '88 EA82 wagon
fud24682000 replied to fud24682000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Good, thanks. Ray Mac. -
With A/C I have both an electric and an engine driven fan. I have an oil leak which appears to be from a front seal, and am hoping to do it myself. Haynes says to remove both fans prior to removing the radiator, but after removing the 4 nuts holding the engine fan to the water pump pulley I can't get the hub off. The 4 studs are about 3/16" too long for the fan to clear the radiator. I'm stuck here---any suggestions? Ray Mac
Is the 1.8 an interference engine?
OK, thanks, that gives me hope. I am also glad that during my search I found out about the other things that should be taken care of along with replacing the belt. Ray Mac -
Hi, Back here again after not needing help for more than a year. My daughter thinks she's lost a timing belt on her '87 GL D/R. She claims she got it home on 2 cylinders. Searching through posts on timing belt replacement, I see that the 2.5 is an interference engine, but I didn't find anything out about the 1.8. If there's internal damage it goes to the wrecker, it's too tired anyway. Thanks, Ray Mac
He claimed he had time to locate the jack where it was stowed, get it out and break the back window with it. I think it's likely that by that time the water was no longer rising and he knew he had enough time. If it's any consolation, he bloodied himself pretty badly going through the broken window However from my own experience with power windows and locks in other vehicles I certainly would not buy another vehicle that had them, too much to go wrong, with or without an emergency. Ray Mac
I'm usually on the older Soob site but am curious about this: Last night a San francisco Bay Area radio newscaster ran his Outback into a flooded area and was stalled before he knew the water was there. The water rose fast. When he was interviewed later he said that he had not been able to roll down his power windows to get out, that the power door locks kept him from opening a door, and that he broke off the door handle trying to open it. He claimed he was only able to get out by going to the rear and breaking out the back window with the jack. Did this guy panic and miss doing something obvious, or is this a design flaw? Ray Mac
Rapid Fire Noise **FIXED*
fud24682000 replied to Seahag1978's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Converter rattle? Ray Mac
