bugite
Everything posted by bugite
on my 1980 gl the button on the dash says passing light.I am missing the door but it does operate. I have a complete set up for a different year but the door is smaller
I have a 98 forester awd 62k, new fluid(cheap stuff) changed it because it smelled burnt,also filter, so i got 6 qts out.It shifts slow from 2nd to 3rd tac.drops slowly from around 3300? to 22000? maby1.5 secounds also it has started to not shift,or delay to drive, it started when very cold now it does it now & then. Any advice? better fluid for sure! band adjustment?
HAPPY DAY i found the problem.i noticed earlier there was a bent bolt/stud in center of tranny cross member,didn't think too much of it. i said before it ia a repairable,hit rite ft.,hard enough to bend that safty stud in tranny mt.and was up against metal transfering every vibration & sound to cross member on into whole body, i think this one is for the books but not your average case, thanx for your help this is a great sounding board, BUGITE
well here's the skinny(any body still use that term?)changed all fluids, rt ft cv shaft,(felt good but changed it anyway,to be safe).checked drive line. still makes growling noise in all gears as soon as you get up to speed.under load no noise,much worse on deceleration,&during shifts .parked it seens to have a viberation when reved.is it time to look for tranny?whats best thing to do.thanx again
reply here?? automatic AWL i think, its a forester S (98) when I bought it i had been hit on rt ft corner, need lower A frame,fender head lite etc. ?i droped all fluids today trany was a little burnt& a small amount of metal flakes & grafite as to be expected the diff's look good,but a did discover what i think as a lose rt side cv i'm in the prosses of pulling right now.i always thought a cv would make a clicking sound on hard turns?not true? i'll be back in a couple hrs,thanx bugite
I'm just getting this repairable on the road,took it for a test ride yesterday & the trany seens to make a lot of growling noise when it shifts & esp.on deceleration also a high pitched whining noise.it seens to be less on excelleration,note:all tires don't match rt ft is33 or 38 dont rember "s but 33 1/2 lf 1/4 & rear match @even 33, please help
I have a 98 forester hit in rt ft corner,I couldn't pass it up.body work is going good but my problem is the flashers come on as soon as I conect the battery.I've checked the wires for shorts in the front,pulled the flashers units under dash,heard the computer box ticking.any one have ideas about this I would sure appreicate the help,thanx
