swi66
Everything posted by swi66
As for "different" systems. There are plenty of different systems on a Postal Legacy as opposed to an american left hand steer car. They are really not designed differently, they are the normal ones as that is the practice in Japan, and a lot of other countries where these cars are the normal ones with steering on the right. The American cars on the left, are the onses designed different. But here I amin America, with the odd ball RHD Legacy.
What I see is a metal cooling line with an eyelet? on the end with a bolt going through it. The upper one is leaking, and crusty with rust. It is located on the (facing forward) left side of the transmission. It goes mid way back onto the transmission, and looks hard to reach due to the tunnel. The lower line is also attached with an eyelet with a bolt going through it, but looks much more accessable. These extend forwards to where the rubber line attaches. They remind me of a frot flexible brake hose set up with a line with an attaching bolt, instead of a brass flare type fitting.
I have a leaky transmission cooling line on our 97 Postal Legacy. It isd pretty crusty and needs replacing. I can tell it has a special end on it for attaching to the tranny. Is this a dealer part only? Anyone ever changed these before? Is it easy/hard to reach? Or should I bite the bullet and take it to someone. I should replace both of them while I'm at it. Ahnd does anyone know if the Postal legacy cooling lines are different than the regular Subaru?
Have a 97 Legacy Postal. Starts, runs, idles, and revs smooth as can be. Head down the road and after about a half mile it sputters, bucks, and quits. Cranks, tries to restart, sometimes it does, but then immediatly dies again. Drag it home, after it has set for awhile, it starts and idles fine again. I replaced fuel filter, but that wasn't it. For some reason, this one has a computer that resets itself when the key is shut off. Last winter this happened once or twice, but it did restart and I was able to make it home. Pretty much parked it for the laast few months and started to try and make it run again. 170,000 miles, and I don't know much about its prior history. We have had it almost a year, and it ran flawlessly for 6 months, but now this. just looking for where to start..........
Wife came home from her mail route with the 97 Legacy Postal RHD and told me the brake pedal felt funny. She said the pedal felt wobbly, not the brakes, the pedal. Sure enough, she went to show me, by reaching down and wiggling it, and it came off in her hand. Not the rubber pad, but the pad and the flat piece the pad was mounted to. Looks like the metal simply rotted away where the flat part mounted to the lever. I am assuming a factory weld there. Looks like I have to attempt to fix it this weekend. Have not figured out how yet. Maybe with my stick welder, hopefully not setting the car opn fire. I hate to think what I would have to do to remove it from the car............. And I would not trust JB weld, with 650 stops a day..............
I had very BAD experiences with both Subaru dealerships in my area. Enough to keep me from ever buying another new Subaru. I would not trust them enough to do anything I ask of them. They did not listen when I told them about problems before, mis-diagnosed other problems, and conned my wife into unneeded work instead of the job I had contacted them to do. Though I love the cars, my modern driver is now a Prius. The Subaru's we keep because my wife is still a mail carrier, and that's why we have the RHD Subies. The 97 we just picked up was from a local letter carrier who got a Post Office provided LLV, and did not need the Subie anymore. I can do all maintenance, change hubs, halfshafts, brakes, struts and have my own scanner, and an in-ground lift to get underneath. Electronics though..........scare me a bit.
Thanks, now I feel like an idiot as I was trying to look upside down under the steering column for it................... Most everything on a RHD is opposite of a LHD car so I will look this weekend for it. Any "issues" with swapping one from another car? Like a 98 for a 97? Both same configuration, same motor, same trans.
As for it being an early production model I beleive it! Vin # is 4S3BK4954V8300819 Could that be the 819th one made? The person who bought it new said it was the first 97 "Postal" in the area. As far as the Postal subarus being made in Japan, that was true of the first Postals, the 91's. By at least 94 they were US assembled. But if it has the early style ECU, why isnt there documentation so I don't have a problem getting it to pass inspection? By the way, where is the ECU on one of these. I tried finding it under the dash, but am not a contortionist, and have back problems. I was thinking of aswapping out the one in my 98 to see if it makes a difference with the one in the 97.
In the paperwork I got with the car. I have found that the previous owner failed emissions last year with the same 4 codes. The receipt was in the paperwork. Also a receipt for a week later passing. I figure that they did the same thing I did, but that does not tell me why? I did see the other post regarding the 96's, but wonder if they might have changed out the ECU. But how will I know which is the correct one?
My 98 Legacy Postal had been sitting low in the back for awhile, and my wife finally had a strut break. I went to NAPA and purchased 4 Outback struts of the same year for the car. I used the original springs for the struts. Measuring the struts against each other there is slightly more than an inch difference. Made all the difference in the world on the car! Rides nice, and a little extra height. And now with these struts in it, I could actually gain even more height by going to outback wheels with a larger tire. I was quite happy with the upgrade and had no problems with angle.
Just picked up a 97 Legacy "Postal" Right hand drive to replace our 98 Legacy postal. When we went to look at it I turned the key on to make sure the check engine light lit up and then started it and the light went out as it should. I took it for state inspection where it failed the OBD II test because it showed 4 "Not Ready" codes! You can have 2 with a 97. I went home and hooked it up to my Snap on scanner. Scanner indicated no failure codes, but indicated that it had 4 "Not Ready" codes. I drove the car around with scanner attached and in short order 2 of the codes went to Ready mode. But upon further testing, I discovered that every time I shut the car off, it sends the codes back into "Not ready" mode. Technically the procedure for inspection requires the car to be off then started for the procedure to be followed. Of course, I had my friend doing the inspection hook up the State OBD II scanner with the motor running and codes in ready mode. He's not supposed to do it that way, but it works. So my question is...........why is the car clearing the codes? Or resetting the monitors, or whatever it is doing? Has anyone else had the same problem? What can I do to fix it right. Is it the computer? Car does have 184,000 miles on it, but it runs excellent, and other than some body dents and dings is in great shape.
So is this the part I need? http://cgi.ebay.com/ebaymotors/SUBARU-LEGACY-OUTBACK-Rear-gate-handle-fits-1991-2004_W0QQitemZ360100526109QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item53d7a9f81d&_trksid=p4506.c0.m245&_trkparms=72%3A1205%7C65%3A12%7C39%3A1%7C240%3A1318 Or does anyone know if the part number for what I need? How about a link to the on-line vendor?
My handle just broke on my 98 Legacy wagon, it has been rusty for quite awhile and sticking where I had to push it back down to unlock the lift gate. Found on e-bay http://cgi.ebay.com/ebaymotors/SUBARU-LEGACY-OUTBACK-Rear-gate-handle-fits-1991-2004_W0QQitemZ360100526109QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item53d7a9f81d&_trksid=p4506.c0.m245&_trkparms=72%3A1205%7C65%3A12%7C39%3A1%7C240%3A1318 Is this a good price? but, I was thinking. There is also this item: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=400040273551&sspagename=STRK%3AMEWAX%3AIT&viewitem= seeing as how my mechanism is probably all bad anyways, should I get this also or instead? And is it the right part from his description? Seller leaves it up to the buyer to figure out if it is correct. Any advice?
Judge out our way has been sentancing maximum time for these crimes. Wish more would take notice. One guy got 10 years for copper pipe theft in a basement. Another guy got beaten by a hocky stick by a 70 year old "victim", left behind his power tools while running away. Was stealing a converter. Another thief was electrocuted trying to steal from a power station. They are even stealing manhole covers!!!!!! But have any "recycling" centers been prosecuted?????? For knowingly accepting stolen merchandise.
