nickb21
Everything posted by nickb21
I've drive the 6MT newer Outback once, it seemed pretty smooth, especially coupled with the electronic throttle. Clutch feel was good, not too heavy, not too light. This is of course coming from my '02 with a non electronic throttle. 16" tires are def cheaper than 17's. You can also get a variety of 16" alloys off other subaru's and I see a fair amount of folks selling "take-off" gen4 Outback alloys. 6MT is still viscous coupler. I imagine the harness has changed between '04 and '14, but the bigger concern would be the dash opening - I don't think the facia is the standard double-din type opening anymore.
Glad to hear you had a good chat with them. Yea, there aren't many yards around here with 'ru's. I'm curious where they end up getting one from. Brass Castle salvage is just up the road, so is Columbia Too, and Route 57 Auto Salvage is pretty close as well. I guess it comes down to final cost, and will you then plan on keeping the car around (if the rest of it is in good shape) vs forking out for a "new" car. --Nick
I'm not a huge fan of Patrick's but I've only heard from a few people who have been there, no personal experience. If it comes down to that I would try Bill's in Clinton, or maybe one of the places in Annandale. Let me know how it goes. Did you already pickup a motor for the car, or do you still need to source that? I'm sure you don't want to spend towing + premium hourly rate, but a place like AZP in Kenilworth would probably be able to do this kinda thing without question. If it wasn't freezing, I had a garage, and an engine hoist I'd be willing to at least say we could take a crack at it.
Thanks, that's def good to know. Are there o-rings in the bottom of the reservoir? Doesn't appear to be any in this pic: http://opposedforces.com/parts/legacy/us_b12/type_2/steering/power_steering_system/ VC's are in OK shape, don't think they're leaking on top of the head. I guess the back of the pump housing comes apart? Maybe it's leaking at the bottom of that and I can't tell.
2000 Legacy L. I did a fair amount of reading, but had a question or two and thought I would try to get things in order since I may only have 1 shot at this (temps finally getting into the 30's this weekend). I've got a pretty solid leak from the bottom of the p/s reservoir, most noticeable on the pass subframe. In addition there seems to be either p/s fluid or oil on top of the pass. side head. The low pressure hose on the top of the pump and high pressure hose (has o-ring which is apparently a common leak) aren't leaking (at the pump at least). I don't think the sensor is, but need to double check (if it is, it's only a drop). Does the pump leak underneath by any chance? My plan is to replace the suction and return hoses (34611AE08A,34611AE09A; which seem like dealer only), and probably the o-ring. Anything else I should check? PCV valve and hoses are clear, guess I need to check the breather on that side though. Thanks for the help!
There is a fusible link on the back of the lighter socket itself that will pop when there is too much current draw/heat. You'll need to pop the socket out to access it. I think I wrapped some thin copper wire 22ga? around mine when it blew. I'm sure the right way to do it is replace it with a heat sensitive wire.
I will throw out a guess - might not help at all. I believe I read that it's pretty normal on this gen when the CEL comes on that at least cruise and possibly stability control become disabled. Also - you can pull the codes through the display on the dash. Edit: Yay google: http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/19053-06-09-how-read-diagnostic-trouble-codes-dtcs.html
Hehe. +1 I've had pretty good luck loosening the lug nuts, and just tightening them ever so slightly, then let the car roll forward a foot and slam on the brakes. Only once have I had to actually drive any distance to free one wheel up. Before doing that you might also try placing a 4x4 against the rim/wheel and pounding on it with a 2-3lb hammer. Works if they aren't too stuck together. I've been coating the surfaces with anti-sieze and so far so good.
I don't know much about the TPMS system, they became standard in Subaru's maybe around '06? So if you look for wheels that age or newer you might be able to buy the wheels with the sensors. There are a ton of wheels that will fit. Outback/Forester wheels use an offset of 48. Legacy/Impreza wheels have an offset of 55. Otherwise both will have the same lug pattern (5x100) and the same sizes 16x6.5 (and 17x7). [Generally speaking; there are a few exceptions]. I did a lot of research and the 7mm difference in offset isn't really a big deal for all intents and purposes. Going to the smaller rim size will be bringing the tire in a bit from the fender anyway. Check out subaruoutback.org, subaruforester.org, and nasioc.com (Always lots of WRX/Impreza wheels for sale there).
