NorthWet
Everything posted by NorthWet
  1. It is unlikely that a ring cracked during storage, or even on start up. The oil rings CAN get gummed up from sitting, and often just fresh oil and some driving will clear that up. The PCV system getting clogged/restricted/gummed up is a likely cause. The PCValve itself may be stuck open or closed.
  2. Any 88-90 EA82 turbo engine out of a sedan or wagon or 3-door will swap almost directly in. ( might be minor wiring connector differences.) ANY EA82 turbo engine from 85-90 vehicles will fit, but might need some of your current external parts (intake manifold, distributor, and/or pulleys) swapped to it. It is unlikely that your engine needs replacing. The oil smoke is almost certainly a temporary issue. Where is the smoke coming from? If out the tailpipe, it might just be oil that seeped into the combustion cambers over the long storage time. It might also be the result of a plugged up PCV system. If the smoke is coming from the engine compartment, is is likely that the "oil leak" has leaked all over the exhaust system during storage and is being burned off.
  3. The axle splines are different and the final drive ratio is different/incompatible (unless you change your rear diff to one from a turbo model).
  4. Copper core is superior in all ways except cost and weight to aluminum core. Dual-row core is hard to find, generally need to search on a TURBO model, and only provides perhaps 50% more heat-transfer capacity (diminishing returns on multi-core radiators).
  5. +1 on symptoms and car details. You can get a screw-in block heater that takes the place of the right-side cylinder block's coolant drain plug. Should be relative cheap... $30-40.
  6. Existing transmission might not need much of a fix. Was there an obvious leak? If so, deal with it. Either way, then refill with ATF and see how it works. Unobvious (non-external) leak is often the vacuum modulator (not what the parts books call it, BTW) having ruptured its diaphragm, allowing ATF to get sucked into the intake. Diagnosis is to remove vacuum hose off the modulator and see if the inside of the hose is wet with ATF. Modulator is located on the right side (US passenger-side) of the tranny, just above the tranny-to-pan joint. Grossgary seems to be the best source for air-suspension info. Search for his write-ups/posts. I would guess that the O-rings are likely leaky. Does the suspension settle downwards overnight? If so, I think that points to the struts themselves.
  7. IIRC, the original bearing was multipiece, and the replacement is the one piece.
  8. I have a daughter going to college in SF Bay Area, and she could use a car. I have WA-state Subarus that I could provide her, but I am at least 20 years out of touch with the CA-state's CARB regs regardling 49-state cars, or older CA-state models. Do cars age-out of the CARB regs, and if so, after how many years? Is it just plain impractical to try and register a 49-state car in CA, especially in the SF region? Any info from Golden State members would be greatly appreciated. and... "Go! Banana Slugs!!!" :banana:
  9. BTW, I LOVE the Maxima alternator in my XT. No messing with the pulley at all.
  10. The 18 inch thing is almost certainly NOT an electrical consideration per say, but rather a practical, mechanical consideration. The longer the length of a piece of wiring, the more likely it is to come in unsecured contact with an object that might cause physical damage to the insulation, thus causing a potential for shorting out the wire. A fused circuit becomes more critical as the potential for abnormal current flow increases... as in, shorting a power wire to ground. Cheers!
  11. Have you checked the Coolant Temperature Sensor (CTS)? The connections on them to corrode.
  12. Basic answer is yes. The engine is non-interference, so no damage will be done when a belt breaks or one gets messed around with.
  13. 93 in the USA is an SPFI, using an optical-encoder in the distributor and all timing set by the ECU. Static advance in the 20-25degBTDC is normal.
  14. Did you connect the 2 green diagnostic connectors before setting the timing?
  15. The transmission will be strong enough. It is unlikely that you will get significant torque increases, and the heads and manifolding limit HP increases. Neither the engine nor the transmission are overstressed in stock form.
  16. To the best of my knowledge, no there is no reset button. In what way was it totalled? Where it was damaged could indicate why it won't start. Otherwise, look for what is missing: Compression, spark, fuel.
  17. There is only one way for the flywheel to go on. The 3 hash marks (III) on the flywheel are used for lining up the timing belts only. the distributor-side belt is lined up first, then the engine is rotated one full turn until the hash marks come up again, and then the non-disty-side belt is lined up. At this point the mark on the cam sprocket on the non-disty-side should be pointing straight up, and the mark on the other side should be pointing straight down. Assuming that this is an 87 or newer, the ignition timing is set by first connecting the diagnostic green connectors that are under the dash and just above the driver's side knee-trim piece. Connect light, and look for standard-type timing marks on the flywheel.
  18. As bratman18 type, non-interference. Great engine. Pretty easy-peasy to take care of if it did. Only non-obvious thing is SLOWLY compressing the tensioner on reinstall. If you have to adjust/change the belt, please ask for more info. What makes you think it skipped a tooth?
  19. The basic notion with reinstalling is that you need to gently push on the TC while rotating it. You are feeling for each shaft seating. When complete, the TC should be sitting entirely inside the bellhousing (IIRC). The tranny damage comes from trying to force engine and tranny together by using bolts to draw them together, If they do'ne push/wiggle together, and still have some fore-aft moveability of the TC, then it is not seated properly DO NOT FORCE ENGINE AND TRANSMISSION TOGETHER. Cheers!
  20. Did you follow the directions on deburring during the cleaning? That procedure works pretty well. The last couple that I have done, I did do a light "hone" on the bore. I wrapped some crocus cloth around a drill bit in a cordless drill, lubed the bit with a bit of ATF, and used that to hone the bore. Regardless, if done well, you probably won't have to clean and debur it again for many years.
  21. Since it started after you diddled with the intake manifold, I would be inclined to start there. Have you checked for vacuum leaks, such as at the intake gasket or a vacuum hose that has gone askew? My reasoning here, other than what was last changed, is that supplemental fuel (choke) helps. The mixture is naturally leaner when the engine is up to running temperature and at cruise power. When cold, it is getting extra fuel due to the choke, and idle runs richer, too. A leaner mixture puts more demands on the ignition system, which could explain why changing ignition parts helped a little. My money would be on the intake gaskets at the head. I understand that with the later EA82 that Dealer gaskets are preferred due to greater thickness making them less leak-prone; not sure about EA81s but would imagine the same.
  22. No, I did mean the transfer gear. The output from the planetary gearbox does not directly feed the rear driveshaft output. It goes through a gearset that has its own ratio to consider.
  23. Gear calculations are all well and good... if you remember to factor in all of the ... ummm... factors. Like transfer gear ratio.
