About Subsforever
- Birthday 05/14/1985
Contact Methods
MSN
glenshumate@hotmail.com
Location
Covington
Interests
Driving, Flying, Bicycling
Occupation
Students
Biography
was normal now with an obsession for Subarus
Vehicles
93 impreza AWD 5 speed
Subsforever's Achievements
Advanced Member (3/11)
10
Took the 97 obs in to less schuab i guess the junk yard sold me a bad hub, got my 93 out of the ditch today, two days and they smashed the passenger side rear window out with a rock in the middle of know were and stole my camelback, tow rope, and come along could have been worse out here you leave something for a week and it will be striped to the frame lucky for me though nothing of great value was in the car for them to steal. i will be glad when i get out walla walla and back to western washington 5 years and im still waiting to recieve any of the so called country hospitality.
Alright me and a friend are working on his 97 obs, hit a curb last winter with the passenger rear tire now it wobbles badly. we replaced the half-shaft the drum and hub assembly one of the swing arms and the rim this weekend and it still wobbles just as bad. so i am running out of ideas can worn bushings or struts cause the a wobble that is visible by an observer and looks to be the same rpm as the tire is turning at i am running out of patience its been a rough week and where down to one car because Saturday i got my 93 impreza is stuck in a muddy ditch and it wont be comming out till it drys out but thats another story. so any ideas about what might be wrong with the 97 would be appreciated. P.S. My apologys for the rant im sort of angry at myself for getting my car stuck and putting my self in this situation.
My friend has a 2000 civic that i am trying to fix. The Civic had a coolant hose i replaced then took it for a test drive and the temperature spiked and the engine stopped a wouldn't turn over again it acted like it was seized and then about 15 minutes later it started again. I got frustrated with it so i let it sit for two months and today when i went to start it the car started but made a terrible squeaking noise that got intermittently worse and the engine would slow, after about 15 seconds the engine quit all together and wouldn't turn over. Oil looks good and i pulled the spark plugs cam cover and timing belt cover and everything looks good. Any ideas what it might be or could anyone point out a good Honda forum for such questions. i have little experience with Hondas having only owned Subaru's myself.
Sounds like a headgasket, there isnt any oil running through your intake gaskets so their is no way they are the problem. my car did the same thing when i blew a headgasket if you look at your dipstick you should see a milkshake on the dipstick and it will probably be well above the full line. this sort of headgasket is internal and all the coolant you add to your radiator is ending up in your crankcase. the coolant oil blend is most likely coming from you pcv tubes that run from your valve covers up to you trottle body boot then it goes into your trottle body and airfilter box.
I was just looking at my 93 impreza wagon the other day and noticed that the rear seat has caps covering up holes for headrests, the back of the seat even has the latch mechanism like the front seats do for adjusting the headrest height. The holes on the rear seat are a little farther apart than the front seat headrests so those dont fit. Does any one know what cars subaru actually put rear headrests on from that age, did the impreza sedans or coupes have the rear seat headrest. I just thought it was strange that the back seats have all the hardware to accept rear headrests but i have never seen an impreza that has them.
Axle breaks and catches on fire
Subsforever replied to Subsforever's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I was wondering how difficult is it to get a reinstated title in washington. I have a friend who will buy it from me if it can be made street legal. -
it radiats alot of heat it looks like it has some sort of shield but there is a hole in it for welding a third pipe onto the top of the cat that my car doesnt use grease can fall into the hole and burn. -
there was a small diference in the inboard axeles cup on the new one it fit though. the alighnment has been bad ever since i have had the thing it pulls to the right. im not sure why but this time the insurance company branded the car -
Fortunately the whole car did not burn during the process I was trying to put it out with the water in my camel back but ran out, fortunately a guy stopped and poured water from a water cooler jug on it to put it out. The new cat has a heat shield except the heat shield has a hole in the middle for a pipe to be welded to which my car doesn’t have so grease can fall in the hole. The car is no longer road worthy due to getting in an accident the week before when a guy in a Toyota Tacoma pulled out in front of me from a side road as I was driving down the free way at 60 I was only able to slow down to about 20 or so before I hit him, his insurance is giving me a decent amount of money for it though 890 bucks but they totaled it to have a salvage title. Right now it drives but I will probably be parting it out soon if towing to a junk yard isn’t to expensive after I have parted it all out. -
how do i lean out the mixture on my hitachi 2 barrel carb there doesnt apear to be an idle mixture screw only a idle speed adjustment screw the milealge has been pretty poor. -
it was on the passanger side but the cat was just replaced last month The old axle i got from napa last year the new axle was from schucks only becuase i was stranded and they where the only place near by. i do not feel the car is safe or road worthy any more and i am just looking to something more reliable i cannot have my car catching on fire. -
Never heard of this happening before but my axle broke on me this last weekend the splines stripped out on the part where the shaft goes into the inboard cup and my boot caught on fire car is an 82 subaru gl the one in the signature. I replaced the axel and 100 miles later the new boot was torn. So now im looking to find a Legacy or imprezza with low miles and/ or good condition for around $3000 in the washington area. must be all wheel drive and a manual transmission. Thanks Glen
