About Tronkus
- Birthday 12/16/1980
Location
Chile
Occupation
Teacher
Vehicles
Loyale 88' 1.8 4WD
Recent Profile Visitors
Tronkus's Achievements
Member (2/11)
16
Tronkus started following Loyale 2.7 Turbo
Hi Guys: Recently i acquired an old '92 GL and take off the dashboard. My car is a 89' DL. I want to swap these dashboard from GL, because my car haven't a tachometer but is not easy to install because the pins are not the same. Any ideas are welcome. Best regards, Luis
Hi Guys: I still working on my car. I need help with some issues...¿Anyone knows if i can swap a dashboard from a subaru GL to my subaru DL?. In first place, the connectors are not the same, but maybe i can do something to fit it? Best regards
...the Third thing is the Fuel injector itself, if your EA82 has the MPFi setup, but if your engine has SPFi... JesZek, i don't understand that part. ¿what do you mean with MPFI setup? my EA82 engine is SPFI Best Regards
Hi Guys: The fuel pump works excellent, no more problems. But...the engine still work on rough idle... I change hoses, fuel pump, spark plugs, check vacuum hoses, but nothing. One piston doesn't work. I check the spark plug and cable and both works correctly, but if i remove the spark cable nothing changes, the engine still working bad I need ideas about what is wrong. Greetings
Yes, arrived yesterday. Here's some pics: It's from a Ford Ranger, i think that i need to adapt the pump because the hoses are more big, no? Best Regards
Hi JesZeK: No, i just use white led lights, the dashboard numbers are green. Looks nice to me. Best regards.
Hi Guys: Finally this are the results: Sorry about the quality of the pictures. I only have to work on the speedometer, doesn't work properly
Exactly, that thread is my guide. Thank You JeSzeK
Hi everyone: I still working on my DL. Today i start to change the ligths from the dashboard: I only have one problem. As you can see, there are many "holes" without lights, so i don't know if i need to buy more leds light or not... Best regards,
Sure! Please send me an PM with the cost.
Thank you for your comment. I don't know how much would cost the shipping, depends on weight and the shipping method or company. Best Regards
Hi Guys: I still working on my car. Unfortunatelly i couldn't find the reroute PCV kit. My car is leaking from on hose of the PCV system. Anyone can help me to find that kit? or sell me that parts? Best regards,
Guys, finally i found the problem in my car. One piston doesn't work, the spark plugs works fine, but the engine still vibrating. i dont know how to repair that problem. Any ideas? Best regards
Arrived yesterday!!!
New stereo!!!! Cheap but very functional...
