3
Everything posted by Ibreakstuff
Thanks for confirmation Karhu. So it would appear there are 2 different TK8 EDM heads, one underlined (gen2) and one boxed (gen3). I ended up coughing up the dough for Drischnie's heads, when they arrive I'll put some valves in and CC the combustion chamber. Then we can compare it to the USDM spec heads (which I think are around 39cc in the heads). I have a piece of plexi with a hole drilled for that.
I came to similar conclusions, it would be interesting to compare the actual changes in chamber volume and how that would effect the compression ratio (lower in the TK8 head). The one flaw to the theory is that the even older molds have the same flat shape as the TK9 head. Over the years on the USMB, it has been quoted that Subaru made changes to the bridge area in the heads. But I see nothing to indicate that they did, at least between gen2 and gen3, other than the casting quality. I know the pressure and temp of the casting will have an effect on ductility and some of these are definitely better castings than others. This is hard to show in a picture too.
My wife only allows one room of the house to have car parts, nothing with smelly transmission fluid either. I traded some closet space for that clause in the contract LOL. I had to have a place to measure/blueprint parts at a normalized temperature, the garage temps swing wildly. With the heads, I'll make an effort to lay them out later and take pictures later today. Most are super dirty, I still have a lot of cleaning to do. Regarding the Euro spec cars, I thought that it was just the computer (EGT vs O2 controlled), and cat free exhaust that opened up the extra power. That TK8 head is the only one I have ever seen with that chamber shape, I sent her a offer on them.. if nothing else to document and cc the chamber volume for comparison. I appreciate the kind words Jeszek
Just looking for some confirmation based on a recent epiphany. We know there are 3 "generations" of MPFI heads, but I am looking for how many molds there were and if each/any have subtle changes. I have found at least 8 different casting numbers and the molds seem to vary slightly. In my possession are MPFI heads with castings numbers TK4 TK6 TK7 TK9 TK10. And recently some EDM heads were posted with pictures showing TK8 (Thanks Drischnie). I know that TK3 and TK5 exist also, just from my stash of pictures. I should note also that most of my heads are from turbo cars, I would be interested to see some heads from NA mpfi EA's (XT4's in the states). The only actual differences between the head revisions seems to be the casting material and the quality of the cast itself. I think it is a myth that Subaru beefed up the bridge between valves and my calipers can't measure any differences. The TK9 heads seem to be the best quality castings imho and I have found a few of them without cracks over the years. I will avoid TK10 heads in the future. What my research has found: TK3 EA82 No lines (gen1) ? TK4 EA82 Underlined (gen2) USDM dot high above stamp TK5 EA82 Underlined (gen2) ? TK6 EA82 Underlined (gen2) USDM line above stamp TK7 EA82 Underlined (gen2) USDM dot just above stamp between E and A TK8* EA82 Underlined (gen2) EDM (thanks Karhu for posting) TK8* EA82 Box (gen3) EDM (thanks Drischnie for posting) TK9 EA82 Box (gen3) USDM smooth/worn casting lines but tight aluminum grains TK10 EA82 Underlined (gen?) USDM both examples I have sharp casting lines but are porous and brittle Notes/etc: -I ordered them by casting numbers, but I am not sure this would be the order they were molded chronologically. TK10 being underlined (often referred to as gen2) is what makes me question this. -The casting number can actually be viewed on the top of the head externally, it will say JAPAN #. The number will match the TK# stamp inside. -The combustion chamber shape appears to be the same on every head except the TK8 head posted by drischnie. This mold intrigues me. -Above the EA82 stamp are 2 numbers, these appear to be the date of the casting. Just month and day, not year unfortunately. I could be wrong and this could just be batch numbers, but the top number is lower than 12 and the second is lower than 31 (that I have found) Any input? Comments? edit: -Added second TK8 EDM head
This would be news to me, I never knew there were 2 different versions of the gen3 heads. Seems like the USDM ones have more meat between the valves just from visual clues. I wonder now if the EDM pistons are shaped different to offset the head volume. My eyes may be tricking me also, but the actual valve angle looks different too. Edit: My gen3 heads are stamped tk 9 and have slightly different casting lines on the cam side.
Could be as simple as loose or dirty pins in a connector. But the advice above is sound, there are many things that could cause it. I had a random start issue that was resolved by slightly bending a couple pins to make a better connection. I found the culprit by jiggling wires on the side of the road in the dark.
- 11 replies
I have a few thousand miles on one of set of the MLS gaskets, but only on stock pressures and stock pistons. I still have not put one together with the head studs and SLA's yet. My wrx (motor #3) and ralliart (crash) have been drawing my attention away. The wife's 02 outback needed head gaskets too (ez30 not fun)... Trying to get back to tinkering with the RX's, the 88 is back in the garage at home. Uncle Sam (tax return) bought me a tig welder and a tube bender this year. I'll be making a couple of EA turbo headers this month.
And Gloyale was right, if they are not dished.. they are not turbo pistons. Would lead to a much higher CR. Even the ej205 pistons I'm playing with, they have a ~14cc dish.
I usually take your word as gold around these parts, but I have to disagree with the performance potential. The "factory" rally spec ea82t made ~181hp and just had a few basic modifications.. intake, lightened rods, and solid lash adjusters. Pretty much everything else was stock. I have the tech docs for modifying for rally spec, but none of the parts are avail. When I get out of the poor house I plan to prove you wrong with head studs, mls hg's, and cooling upgrades. Edit: I've posted these, but I'll just steal the link from ausubaru (Thanks Gannon): http://www.ausubaru.com/coppermine/albums/userpics/rxModManual.pdf
Yes, you could easily disconnect it to test also. Edit: The HH is the first thing I remove, I wouldn't trust any HH on a steep San Francisco hill anyways.
- 127 replies
- dual range
- trans swap
(and 1 more)
Tagged with:
Definitely don't run lower octane gas, you are asking for detonation there. If you connect a knock sensor back up, it should pull timing if a actual knock is detected. Can you take a video or sound recording of it? Rod knock is pretty rare on these motors. My guess is HLA tick tho, 5w30 is probably too thin. I would try 5w40 or 10w40 if I lived in your region (maybe even 0w40 for winter). Amsoil 15w50 dominator is my new favorite ea82t oil, but I live in a much warmer climate.
Sounds like the clutch cable is too loose and it is not fully disengaging when you press the clutch in.
- 127 replies
- dual range
- trans swap
(and 1 more)
Tagged with:
For hsoj and 175eya: (thanks to numbchux) http://www.ultimatesubaru.org/forum/topic/63821-pics-of-lsd-conversion/ The carrier is the guts of a diff, the part that does the work. The idea is to replace the open carrier with the lsd carrier but keep the ring, pinion, and case matched. Edit: More good reads.. http://forums.nasioc.com/forums/showthread.php?t=2597453 (the clsd shown here is ours, 2way plated goodness) http://www.scoobymods.com/showthread.php/diy-upgrading-replacing-rear-differential-14270.html
- 127 replies
- 1
- dual range
- trans swap
(and 1 more)
Tagged with:
You could do the old suicide trick, pump the exhaust gas into the garage for a few hours. Try not to kill yourself in the process. Nothing survives the summer in my storage unit.. mice, spiders, and moths all succumb to the heat. I prefer to have a car survive the summer in the box before working on them lol.
