About wagonlover
- Birthday 12/29/1994
Location
OC
Occupation
student
Vehicles
1988 Gl-10 wagon
wagonlover's Achievements
Advanced Member (3/11)
0
do you have to take it out through the bottom or can it come out of the top?
So i took a look at my radiator and it looked pretty bad so i decided to just go ahead and buy a new radiator and thermostat. Im currently removing the old radiator and it looks like a pretty tight fit to get it out of the car, do i need to remove any part of the bumper or should i take out the fan or something?
183xxx miles and yes it is the original radiator
Its at highway speeds, havent had much of a chance to look but i know my coolant is at a normal level, i think i might be having problems with my fan
The past few days have been hot for portland and my 88 gl-10 has been running pretty hot and today it broke into te red zone on the temp gauge from just driving for 30 minutes in 100 degree weather. It also runs very hot if i turn AC on. Any ideas?
So its pretty easy to install the boost controller? Where does it go? and that pretty impressive that you were getting 10 psi out of it. Maybe If i get a top mount for my car I will order one of those.
I removed one of them and it seemed to help a bit but I didn't want to take out both because i figured I would lose all back pressure.
Could you tell me the brand/model of your boost controller? Did you put an intercooler on your car or anything else besides that?
Hahah yeah i didnt think there was really anything i Could do but i was curious because there has been alot Of things on this website that i learned about the old ea82's but oh well i guess i better start saving up for that ej!
update: I ended up removing the exhaust right before the second cat and It is ALOT louder than it was before, but I really don't want my exhaust just dumping right under my seat so I am just going to buy a flange and weld it to a pipe with my cherry bomb and have it go out the side of the car like you suggested, then i can just unbolt that and put my stock exhaust when needed for DEQ
I have a stock 88 gl-10 and I would like to do somethings to maybe make it a little bit faster without doing a full ej swap so any one have any suggestions for what I could do?
I have a little 300 lb pop up trailer that i would like to pull around with my 88 gl10 wagon. I have found some trailer hitches online but im not trying to spend a lot of money. Does anyone know where i can get a used one or one that would fit from a different car? I want one that has a 1.25 inch reciever.
Does anyone know what the emission laws are like in oregon? Don't worry though if i do get in trouble for it i wont tell on you guys
