old sub freak
Everything posted by old sub freak
  1. hey israbrat.nice turn out. hers 2 of my subarus check em out. could i drive them over there?http://communitywebshots.com/user/todds173 take care todd
  2. hey mr. b, how about the international brotherhood of subaru FREAKS!!take a look todd http://community.webshots.com/user/todds173
  3. hey rinatm, i finally got my pic on line.hope you can c them .take care over there todd
  4. hey man, first thing i would check out would be the oil sending unit. they are known to read low w/age.try a new one[$25,30] bucks.resealing the pump $12 kit perty basice, now to pull the thing!!!!on a earlyer link[thread]we talked in depth about extration. they can be easy or<>?#$$%! pull of front pully ,then the 4 bolts. GENTLY pull up/down on oil filter,wd40ect. i use a small pry bar small wood block[as a shim, don't pry on the :plate they can brake off the "ears"i pry the horisontal"bolt afair"[over flow valve?] on front of pump ,with shim on block ketch the tip of bolt affair with your pry bar again rock oil filter up/down while putting presure on the single bolt on the front.take your time and "woory"it out.they seen to come out easer w/the motor hot.it can take 10 min or hours. some times i only got movement out while pushing down on filter.take your time its a main leak area.you'llbe glad when all the new seals are in.no more leaks good luck todd
  5. hey bb, i should have explaned more. you shouldn't pry between the "plate" and the block.{i learned the hard way} i use a small pry bar ,a block of wood[for a shim] and pry off the "horisontal cap bolt afair "[over flow valve?"]on the front of pump while pulling up/down on the oil filter. use wd40 ect and baby it off. i've even filed the "plug" to make it easyer to install.tape off holes in pump so no filings get in.its worth the work .the seals are usualy hard and break in your hand. as long as you didn't break off one of the "ears", clean up any nicks so it fits flush.and you could get by. good luck todd
  6. hey tyler,we used rubber{napream?}thicker than iner tube,1/8"or so .i punched the hole so it fit tight and cut to fit.then kind of molded it{j/b} to hold the rubber,the stuff sags so we used duct tape as a "mold".i sold it 2 months later still ok.it was a last dicth effort. we considered "welding" a stock gasket,but well you know.hope this makes sence. good luck todd. some pic of my haz-mat hatch and the" thrasher" http://community.webshots.com/user/todds173
  7. the pump has a "plug" that fits into the block. just rock it up /down and GENTLY work it out. don't pry to hard it will break.they can be easy or!?#$^. take your time.it will come out.good luck,todd
  8. hey tyler, the seal is in the tranny! i was told to split the case ect. . instead we used j,b liqid weld and made a exturnal ruber gasket.clean around the "area" good, make a tight gasket,"weld" in place, almost encased the gasket,tape in place, let dry over night.it really worked!took some time but so does tulling the trans. good luck todd
  9. hey israbrat,i thought no "fancy" stuff on your rigs over there??or is it different town to town? like i said i thought wild trucks were all over the middel east different countrys??anyway take care todd,check out my wild rides http://community.webshots.com/user/todds173
  10. hope this works http://community.webshots.com/user/todds173 we'll see ,todd
  11. hey rinatm & israbrat, i almost figured out this webshots thing,pic @todds173 on webshots. can't figure how to put on board? hopfully pictures soon ,take care todd
  12. hey rinatm, my mistake,next time i'll say people.i'm still shocked to "talk" w/people across the world.so most brats are 2 wheel drive. i've never seen one.do "they" say why you can't change tires, 4x4 ect.? and the americans cry that we got it bad. i'd be jailed for my brat over there. anyway you take care over there, todd
  13. hey rinatm, not to be off subject but...i,m novis to this internet stuff.i never thought in a million years that a guy from israel,alaska, iowa,and washington state would be "talking" about brat tailgates.....i this cool or what! anyway old stock parts are the easyst fix, with ample junk yard parts it seems . i'm surprized how strict about tires ,tailgates ect. i always thought of israel trucks w/wild paint jobs, tapistry headliner, lookin cool! do some look that way? anyway sorry for being "off subject" if i can figure out how i'll send pic of my brat. take care todd
  14. i had a 81 w/ the same problem. it got stuck at 4-5000!! the gas pedal "rod "was rusted bad. i ended up taking the whole assamble off the floor,filing off the rust, oil the heck out of it. and better than new. good luck todd
  15. if your guage is good,30-40lbs ,steady readings you should be ok.things to bring up presure. new oil pump or new seal kit for oil pump,20-50wt. or stp. we used it 30 years ago to bring up oil presure in studabakers ,packards and even hilmans,its a band-aid but will get you lots of miles if used regular. take care todd
  16. the oil sending unit on ea81 are known to read to low when they go bad. try a different unit it may fix your problem good luck ,todd
  17. hey, i've had same problem ,just above the hood releace there is a relay? there is 5/6 wires coming out of it. its green or black 1.5"x1" i was told this unit is the roll over safty thing. the screw holding the hood relaese holds the relay. i by past it in a jam, and replaced it later. i found the hot wire and gently tested the other wires to get pump going. i broke the old one open ,greek to me but a nother used one fixed the fuel problem good luck todd
  18. and front cv joint, lower control arms get bent and exust studs.but they can take lickin and keep on THARSHING!!!.a good trick to pull the cvj through instaed of a slide hammer is use two old front wheel bearings. push through as far as you can. ad one bearing tighten casel? nut, remove add#2 tighten. you need to pull oil seal first, but 2 old bearings can lay at bottom of your tool box w/out taking up much room. have fun todd
  19. iv'e seen many of those,the ones that are cracked bad will be really clean {preasure wasned w/coolant} iv'e also seen the cracks peened w/ a center punch, to try and fix them??? and the old school test.lay head out side and fill cyinder"head w/gas and time how long it takes to drain out. or not. as i recall if 1/2the gas is still there in 10 min.your good to go. or something like that, the more gas retained the better. good luck todd
  20. hey ken,yea being tall w/a brat can have its hassels. last summer i got a recaro seat at a yard sale $20 . it lined up with the stock tacks onder the seat.2 bolts lined up and i drilled 2. its a comfortable seat and it droped me at least 2", i like it. hey i know its not subaru but you could cover it w/ some thing. anyway take care and i'll see you at hood river or? todd
  21. yes,that is the sign for broken belts. but not all is lost. i did my first timing belt a year ago. it just takes time ,get a good manul ,there might be a link that has more detail? good luck todd
  22. check the freze plugs under rocker arms. my brat was the same way. i lucked out ,just cleaned plugs and reinstalled. maybe???? good luck todd
  23. my vote would be 81-84 4x4w/hi/lo ,there tough, cheap to keep going and just so cool. right!! todd
  24. good plan. i'v bought new trans mounts from dealer, and thought they seemed "loose" feeling. thanks for the details todd
