About Recian
- Birthday 07/12/1988
Location
New Bern
Occupation
Nissan technician
Vehicles
1995 Impreza L AWD 2.2L
Recian's Achievements
USMB is life! (4/11)
0
Makes sense seeing as when i back up out of a parking space and cut the wheels it'll stop. So i'm looking at a trans overhaul then Just out of curiosity could this be the same reason after going over speed bumps the car kinda rocks a little, if you give it gas it'll buck and jump back and forth really bad like bad motor mounts which i just replaced with a set of megan racing ones. Runs better but didnt fix that issue. How much do they run on average if you can find them? i can find 02+ WRX ones but not pre 02
Im curious if this is just a characteristic of the AWD car but my impreza when i take u-turns or tight turns in 2nd gear (usually 10-15 mph) it'll bog very low and lose all power or it'll buck really bad where you've gota push in the clutch throw it in 1st and stomp the gas to keep it from bucking over 3000rpm. If you let the clutch out too fast (almost like dumping on a 2wd but not so aggressive) it'll buck like that too. Im wondering if this is just a characteristic of AWD or do i have a MAF problem?
Fine i dont like how cable clutches feel and i never have lol by the end of the year i'll have my frankenmotor built so it'll be easier to go ahead and just convert it to hydraulic. (honestly i think it's easier to pull out the clutch fork by yanking the engine rather than the trans) Plus the cable clutch isnt made to handle the stiffer clutches. Stage1s like the one i've got are ok but anything higher and the cable isnt made for it. Plus they stretch over time where the hydraulic may blow out a component which is easily replaced.
The trans fluid should have been changed half way through those miles. autos are very sensitive to the fluid. Hydraulic fluid will break down by time and mileage more so than other fluids and can cause problems. The fact that you can turn the car off and restart means you most likely have a problem with the shift solenoids in the valve body. If the key cycle didnt help i'd lean towards fluid or clutch related issues deeper in the trans. If it's electrical you should have a stored code. I'd recommend reading this thread. http://www.ultimatesubaru.org/forum/showthread.php?t=117234
So really i could just replace it with something like this: http://www.ebay.com/itm/TORQUE-SOLUTION-DRIVE-SHAFT-CARRIER-BEARING-BUSHINGS-SUBARU-IMPREZA-1995-95-/190607733756?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c611b33fc&vxp=mtr OEM says not servicable so finding new rubber bushings is out of the question.
I think i've found my clunk when i take off. I can reach under the car and move the drive shaft support bushing and it'll make the exact same sound. The bushing itself is fine but the 2 grommets that the bolts go through are the problem. I can move the frame when it's bolted down and hear the clunk at the 2 bolts. Can these 2 grommets/sleeves be serviced? or do i need a whole center bushing. If so how are these center bushings removed from the drive shaft? I have a custom drive shaft due to swapping my car to m/t so i'd prefer not to buy a new shaft.
stick with 90-94 imp or legacy. My 95 imp had a different starter when i put in the 93 legacy m/t. I had an a/t. The parts houses all list the starter i had (shorter) for the 95 whether it's a/t or m/t. The flywheel is shorter on the m/t than the torque converter teeth of the a/t so the m/t starter is longer. I know the legacy is the same because that's the tranny i'm running in my car.
That's what i was going for is clutch pedal feel. I've never really liked the way cables feel. I always feel like i'm going to break something because of how much of the drivetrain you actually feel. Hydraulic are the same feel from top to bottom, there's nothing pushing your foot back up. For a daily i'd prefer a better softer feel. Just curious is all
