saltybeefcubes
About saltybeefcubes
- Birthday 06/11/1989
Location
Rocklin,CA
Occupation
Noodles and COmpany
Vehicles
90 Subary Legacy LS
saltybeefcubes's Achievements
Member (2/11)
0
So basically what's happening is the car will be cruising just fine and will even shift into 4th once my speed is fast enough and cruise below 2500rpm's. However, after a few seconds, the car downshifts itself back into 3rd and the rpms shoot up to 3000. To maintain freeway speeds (65mph) the RPMS are pushing into the 4000's. My speedometer does "click" and wobble a little bit but is still very much accurate with my speed so I could see that as being a probable cause. Although I couldn't see the car shifting into 4th if that was the problem. I've read a few things from: the car being in limp mode, perhaps the cable adjustment is a little off, or the 4th gear is pretty much shot. Any insight would be GREATLY appreciated.
awesome, that's good news because my cable was bad on both ends. I easily fished it through the fire wall so it obviously wasn't attached to the dash and the little plug into the trans also looks bad as it appears that the little "flat head looking piece" snapped off in the old transmission and it also fell out of the plug once it was removed from the tranny.
Welp, I checked the trans code (both current and previous) and they both came back normal. So it's obviously the speedo cable. Now which part of the cable, I don't actually know, but I'm hoping that it's not the part that goes into the dash and is the part that plugs into the transmission. Now if it is only the cable, is it still a possibility that it's effecting the transmission? Or is that probably a no go since all the sensors are fine and the trans is just bad?
From the edge of the world
saltybeefcubes replied to Libero's topic in Meet n' Greet. Your USMB Welcome Center
Forever jealous of your justy. I can never find them
