saltybeefcubes
Everything posted by saltybeefcubes
So basically what's happening is the car will be cruising just fine and will even shift into 4th once my speed is fast enough and cruise below 2500rpm's. However, after a few seconds, the car downshifts itself back into 3rd and the rpms shoot up to 3000. To maintain freeway speeds (65mph) the RPMS are pushing into the 4000's. My speedometer does "click" and wobble a little bit but is still very much accurate with my speed so I could see that as being a probable cause. Although I couldn't see the car shifting into 4th if that was the problem. I've read a few things from: the car being in limp mode, perhaps the cable adjustment is a little off, or the 4th gear is pretty much shot. Any insight would be GREATLY appreciated.
awesome, that's good news because my cable was bad on both ends. I easily fished it through the fire wall so it obviously wasn't attached to the dash and the little plug into the trans also looks bad as it appears that the little "flat head looking piece" snapped off in the old transmission and it also fell out of the plug once it was removed from the tranny.
Welp, I checked the trans code (both current and previous) and they both came back normal. So it's obviously the speedo cable. Now which part of the cable, I don't actually know, but I'm hoping that it's not the part that goes into the dash and is the part that plugs into the transmission. Now if it is only the cable, is it still a possibility that it's effecting the transmission? Or is that probably a no go since all the sensors are fine and the trans is just bad?
From the edge of the world
saltybeefcubes replied to Libero's topic in Meet n' Greet. Your USMB Welcome Center
Forever jealous of your justy. I can never find them -
Yea, the reverse lights are operative. I do not notice any lights coming up on the dash (though they could be out too). I was told that the connectors behind the battery that come from the intake manifold have the coolant temp sensor and other associated wiring from the engine. So I'm starting there and hopefully can hopefully figure this out. Electrical, is VERY frustrating.
Basically I swapped in a different trans since mine was blown. The transmission that is in it now will not shift out of 1st when it's in drive. However, if I manually shift it from 1st to 2nd to 3rd it goes in just fine. Also all my dash gauges (rpm, mph, gas, oil, etc) are all non operational now. My question is: would these two things be related? Because if the car cannot register how many MPH'S it's going would that be the reason that it won't shift to second? Any insight would be EXTREMELY helpful because I'm legitimately stuck with this.
How's it going everyone. I'm new to this forum (I'm also on bbs.legacycentral.org) but pretty familiar with Subaru's. I'm current working on a 1990 Legacy LS Wagon that I got $400 and doing my best to bring her back to life. I like the 1st gen Legacy's the most,mainly for the good platform and it's a car that I can actually afford. But I'm also on the hunt for a Justy (my all time favorite Subaru). I plan to be pretty active and I really enjoy the Subaru community. Also I love Game of Thrones, Skyrim (huge player of Oblivion and Fallout as well), Diablo 2; hopefully 3. Thanks!!!
