Everything posted by ckgeorge
Okay, I will have to look into that for sure. I'm sticking to fwd this year and will probably look into something like that next winter. And I hear yah, owning multiple older vehicles myself there is always something going wrong with at least one of them!
Thanks for the heads up! I usually go through a set of wheel bearings in the front every year or two... I'm sure they weren't designed for the track width and lateral forces they are experiencing. I suppose as with most things on this car I will have to get creative with the rear setup. Awesome to hear you will have the coupe back on the road again soon!
Thanks man, I will keep that in mind. Cheers!
Sure do! It feels like cheating but makes tuning super easy. It's amazing to see just how much the mixtures change driving at sea level versus up in the mountains. Haha, true that regarding the center diff... I do want to go to a platform that came RWD from the factory so I can swap the engine and trans then just get a driveshaft made to connect to 4wd rear running gear. That whole project wont begin til next winter though as I'd just like to get the chassis sorted and have some fun this season.
Thanks man, I'm actually planning to go rear wheel drive. Still deciding what engine I'd like to go with but strongly considering a carbed 13b rotary and trans setup. With some porting I'd like to be in the 150-200 whp range... nothing crazy but plenty for what I do with the car. Cheers!
Nice build! You must have put er on one hell of a diet to weigh 2280 with a cage... I bet it's a blast to drive.
My pleasure... I will be sure to post an update when I make some progress on the roll bar. Cheers! Thank you! It sure is a blast through the twisties and handles like a go kart... I would definitely recommend.
After tinkering away for a few more weeks I figured Id post an update. I decided to swap the chassis bushings with poly Superpro bushes as it wouldn't make much sense running slicks with 34 year old bushings. The only bushings I was unable to find in the aftermarket were the transmission cross-member and the rear sub-frame bushings. Here are the part numbers from the ebay seller. I don't own a press but this tool was a life saver. It might be from launching on sticky tires at autocross but I seem to go through a CV axle a year and find the Cardone axles to be junk. I found this "heavy duty" set on Rock Auto from TrakMotive so we'll see how they fare this year. A rotor freshen up and new CV's, bushings, and semi metallic pads in... along with a power rack with lines looped as a manual conversion. While I was at it I decided to replace the engine and transmission mounts. In the past I've had problems with the exhaust heating up the steering rack boots causing them to crack so I decided to pick up some DEI header wrap to mitigate the problem. As you can see I had some leaky rocker cover gaskets that left their mark... rust prevention anyone? I've had great success using Remflex header gaskets on my small block chevy and wanted to give them a try on the GL manifold... this part number fits perfectly. The custom Diamond racing steelies showed up so I had the slicks mounted. The specs are 13x10 5.5" backspacing and they seem to just clear everything inboard with no rubbing. I think the setup looks pretty tough and can't wait to take them for a spin on course... til next time!
Hey man, sorry for the super late reply. Looking forward to seeing where you take your build... I bet those Ohlins are gonna ride great! I'm considering making my way down for the Old School Reunion again this year and would like to meet up if you're attending and check out the coupe if you get er fixed up. Cheers!
Hey man, I love what you've done with your coupe... I actually just found a photo of our cars that I took at that meet and set it as my cover photo. After a quick drive on the street the car feels much more responsive with the BC's and surprisingly not too harsh. The first autocross is in March so we'll see how they hold up there. How do you like the Ohlins in your coupe? My pleasure! The car wouldn't be where it is today without the research people have done on this forum so it is nice to be able to return the favor for once. I hear yah, I'm always bouncing back and forth between this and my '85 c10... it's hard to "finish" a project vehicle when you have more than one. I look forward to seeing what you do once your '77 is complete.
Hey Everyone, I haven't posted on here for years and thought I would share my build progress and findings. The end goal of this build is to have a fun autocross machine and weekend canyon carver. To start off this car was given to me as a grad present from my grandmother 10 years ago and I daily drove it for many years before tinkering with it. The car is an '86 fwd coupe with a 5 speed. This is essentially what the car looked like when I received it at only 80,000 kms. Currently the car sits at 275,000 kms. For the past 4ish years I have been autocrossing the car on and off while making changes to improve the handling and grip. I feel this chassis does have potential and certainly has light weight(2100lbs currently) and a low center of gravity going for it. I have been asked why not jump to a newer platform such as a BRZ/FRS for autocross but the challenge of making this a competitive car seems to keep me hooked and will be far more satisfying in the end. Up until now I have made several undocumented changes to the car such as a Weber carb swap with a wideband o2 for tuning, 6 lug conversion, 15x8 -19 wheels with 225/45r15 BFG Rival S tires, Ground Control coilover sleeves with stock struts up front and KYB AGX NB Miata rears, 2002 WRX seats, slotted rotors with semi metallic pads, Momo Prototipo steering wheel, RX body kit and Datsun 240z fender flares. The car has been like this for the past couple of years but it is time to make some changes. Addco 7/8" rear sway bar added to reduce understeer and increase lift-off oversteer for rotation. Fabing up seat rails with original brackets to fit bucket seat. Omp First R bucket seat fitted to keep me in place. I have always struggled to find a decent suspension setup while maintaining stock hubs and I have finally come up with the answer. The BMW e30 chassis has the same diameter front strut tube at 45mm. This allows you to fit a BC Racing coilover weld-in kit designed for an e30 on the front along with GV Impreza coilovers for the rear. The folks over at BC Racing allowed me to place an order with the BMW fronts and the Subaru rears. If anyone else decides to go this route the part numbers are I-04-BR for the front and F-08-BR for the rear *You will have to use Impreza camber plates up front as the BMW bolt pattern is different up top and the stock shock mounts out back*. Since this car is no longer a daily driver I decided on 10k springs up front and 12k springs out back. All you have to do is chop off the factory strut, slide it into the coilover base and weld it in. I decided to chop an additional inch off the coilover side to get the desired ride height. Here is the finished product with GC Impreza camber plates up top and helper springs added to get the desired ride height. As you can see this setup allows you to gain much needed camber/castor adjustment as well as dampening/rebound adjustment. This is how the car currently sits with the new BC Racing suspension in. Next on the list is 10" wide slicks on a 13x10 6 lug wheel. I am currently having Diamond Racing wheels built to spec and will post an update when they arrive. Now that the suspension is in order and a racing slick setup is on the way chassis flex is going to have to be addressed. I picked up this roll bar kit locally off craigslist for an s10 pickup and it seems to be a pretty close fit. I have begun the planning process and will post more updates as the progress continues. Thanks for reading and feel free to ask any questions regarding the build. Cheers!
Sorry to hear you are not a fan of the work I have done, but at the same time you can't please em all. I wanted to go for a classic japaneese styling that I had not previously seen done with an ea82. I am simply having fun experimenting with the car and everything that I have done can be reversed if I decide to restore it in the future. Either way I appreciate and respect your opinion.
Small update... Since adding the FJ60 wheels and flares I have added ground control coils and purchased some BFG Sport Comp 2s 195/50r15. Was able to get an inch or so lower and the car handles pretty good now. Also plastidipped the wheel centers and grille for a little more contrast. Next on the list is tracking down a rear sway-bar and replacing the worn out control arm bushings.
I'm aware that he has a very cool Leone and I wish him the best of luck in finding some bumpers... However I am quite fond of mine.
Lol, that some kind of joke? I am not selling any parts off of my vehicle... sorry.
Well, it has been some time since my last post but I figured I would do an update as i've just completed a weekend project. Got sick of the 13's so fj60 wheels it is!
Hey there, maybe I can help you out here. I recently bought xt struts to lower the front of my car but unfortunately they raised it. They ended up being 4wd struts but listed as 2wd ones. The part numbers I purchased were Monroe 71876 and 71877. Whats really weird is one side sits an inch higher than the other since one strut is an inch longer than the other. After doing some more research the only 2wd xt struts I can find are KYB number 234029 and 234030. Good luck!
Haha, I hear ya man. My rear fender wells are starting to rust... makes me sad. BC, why you gotta rain so much?!?!
Thanks man! I too looked into getting collector plates, but as you previously stated I can't because of school
Lookin' good! Like the shot in front of the dealership
New photo...
1986 2wd 3door coupe leveling question
ckgeorge replied to ckgeorge's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Cool, I will give that a try first... Thank you for the reply -
nope 2wd
