jgruber
Everything posted by jgruber
  1. i am not sure. wife broke down on highway. timing belt(left) shreaded. replaced both belts. still no fire from coil.new coil still no fire. ecu says codes 11 and 13. nxt step dist replacement?dist cap removed ,electrics unplugged, asjustment/hold down bolts removed. have to use hammer and punch to get dist to turn.will NOT lift out!
  2. 1993 loyale 1.8 vin 4.i was told the crankshaft position sensor,the camshaft position sensor, and the ignition module are in the distributor and cannot be serviced. replace the entire distributor as a unit to repair ecu codes 11 and 13. any help would be greatly appreciated!
  3. :horse:cannot remove distributor. trying to repair crank aangle sensor problem.
