jheat71
About jheat71
- Birthday 08/10/1971
Location
meridian
Occupation
self employeed
Vehicles
I Love My Subaru
jheat71's Achievements
Member (2/11)
0
diffs r fine fluid looks good and no metal ............ so can the rear transmission mount cause this kind of vibrations remembering that the vibrations feel like a out of balance washing machine especially when i am going up hill ( really bad ) ? and are the DOJ's the axles sorry i'm not a mechanic ....... thanks again for all the help everyone
sounds good .......... ok axles this week ................ strange thing though when i picked up the car from the mechanic he said he did find something wrong it was the rear transmission mounts were both broke , just wondering if this could also be part of the problem ? thanks again everyone when i take the car in tomorrow i will have the axles replaced as well as the transmission mounts
my mechanic was ready to put in a new axle and then said i didn't need one ........ had another shop put the car on a lift and they checked the the drive train ............ so here are the symptoms the car will vibrate and only vibrate when you press the accelerator ( the vibrations or shaking is in the drviers seat area ) when going up hill the car will shake 10X as bad almost as if you're try to rock the car back and forwards .............. so next on my list is the u joint and trans bushing and maybe wheel bearing ( none of the wheels seems to show any issues no wobbling or signs of being out of balance
i have had the tie rods , axle , drive train , tires changed and balanced , the vibration is more pronounced when the car is going up hill and yes when u speed up the vibration increases but again when u go up hill it feels as if the car is going to shake apart ............. like something is out of balance bad
no i have not tried the AWD fuse ........... should i remove it ? not sure about all this ............ what i do know is that the vibrations are at there worse when i gun the accelerator and a lot less when i slowly accelerate ( but can still feel it ) and the vibrations is coming from the front end ............. very baffling, i have been told by the mechanic maybe drive train , torque converter , transmission , axel , or transfer case ............. not wanting to replace all of this if i don't have to .................... ok everyone what should i check 1st second and so on ...... again i appreciate all the help
ok i have had the tire rotated balanced and checked for splits all that is ok. The mechanic did say that there was a little warp on the driver side front axle but he said that should not cause this bad of a vibration ....... now that being said i just remembered back in may we pulled a code from the car ( check engine light came on ) and it was for a torque converter locking up could all this be related ?????
Ok so my girl has a 2000 2.5l outback 239,000 + miles , about a week ago the car started to vibrate while accelerating . The harder you push on the accelerator the worse the vibrations( although when u let off the accelerator the vibrations go away ) , feels almost as if a tire is split but had them checked out, balance is ok to . A local mechanic thinks it maybe the transfer case or torque converter any suggestions on how to diagnose this problem ? ... there are no subrau dealers close
so i just check the trans fluid , not sure if i did it right but when i let the car idle for a couple of minutes and then checked the level (while it was idling ) it barely registered on the stick, so i added a quart and right away i noticed the idle even out to around 800 to 1000 rpms , before the idle was around 1200 to 1500 .......... so i am going to the car set for a few hours and look for a leak ............... could this be causing the issue's i am having??
My girl has a 2000 subaru outback , manufacturers date was 10/99 she is looking for a good honest mechanic in the Meridian Ms ...... the closes dealer is in Jackson Ms and is to far for her to travel too.......... so if anyone know of a good mechanic in my area please let me know thanks everyone this Forum is awesome and been very helpful
thanks tex this helps , a couple more questions when u mention 3 drain and fill cycles , does this mean how many times i should drain and fill the trans an if so what are the intervals for that ......... what is the best tranny fluid to use on the car manufacturers date was 10/99 and does anyone know of a good subaru mechanic in meridian ms ? , the closes dealer is a few hours away
