94Heritage
Everything posted by 94Heritage
  1. Thanks for the input guys. I think my best option would be to replace the motor. I just found a '99 EJ22 for $700. 4 months warranty. I might do it
  2. Hi all, I'm hoping that someone can help me here. This vehicle has done 307K. Timing belt has been replaced, etc. First problem has been with the car for 3 years. (frustrating) First problem.. On a cold start, fires up good, drives good, but within 4 km, it starts to misfire, (dead miss) then slowly gets worse, until unable to accelerate, loses power and speed, then stalls. By the time it does stall, sounds like its on one cylinder. My son has reported seeing white smoke under the bonnet and out the back. If you wait for 5-10 min, it will restart, misfire clears, and your good to go and won't do it again while hot. Does not do this every day. Second problem..Cooling. I'm thinking head gasket. Short trips, no probs, gauge sits on a bit below 1/2. Long trips, gauge moves up to 3/4's, and upon pulling over you can hear the water boiling in the engine. Most times, top hose has no pressure, soft. After 5 min, hose has pressure. Coolant bottle is quite full at this stage. Wait until cold, and coolant bottle is empty. (drawn back into the system) No obvious signs of water leak. So, questions with the cooling. What symptoms does a faulty thermostat have?, and also a blocked radiator have?. Or has it done a head gasket? Will eagerly await your help, thanks.
  3. Hi all, and yes i drive a '94 heritage wagon. Its been a good car, and has 307,000 k's on the clock. My son has been driving it for the last 3 years, and now its my turn. I have a few issues with it, so i will post in the right section and hope someone can help me out. Great forum you guys have here to.
