gilty
Everything posted by gilty
  1. Will a lift kit from a gl wagon fit a hatchback? Or how much could be used?
  2. Yes it was the switch on the steering wheel. Thank you. I have lived this problem before but forgot this subaru quark. Will work on the idle next. No codes or check engine light on, which seems weird. Usually any hic up and that flipping light goes off, but not now. Maybe I should be happy with that.
  3. 1998 Forester replaced engine with similar 2.5 dual cam. Now the parking lights stay on, related? I unplugged the multi function head light, turn signal, dimmer switch on the left of steering wheel but lights still on. Any suggestions for where to look next. I have been disconnecting the battery if left for more than a day, but that gets old. Also have a stumbling idle and sometime it dies when waiting for a light. Fuel filters? Injectors? spark plugs? The plugs on this motor are a pain to get to.
  4. How do you get an early 90s legacy torque converter to seat the last 1/2 inch. Frustrated.
  5. Hello, I have a 1986 gl 5sp fwd stock carb ea82. It will start and run at a high idle for 20 sec or so then die. The ECS light comes on. If I spray some starter fluid I can keep the car running.The carb was rebuilt recently. The fuel pump seems to work fine.Where should I start to fix this?
