vamos's Achievements
Member (2/11)
0
the heater core may be partaly pluged will slow coolant and make gurling sound shouldent realy matter make shure you recheck level after its cooled down may have to be topped off
i do it not running because air gets traped make shure you have the rad vent cap open on right side of rad top fill trough the rad cap till comes out vent cap with no bubbles helps to have the front end up a bitt takes some time fill wait fill wait it may have a slight bitt of air in heater is ok when your confedent you have most of the air out run it with caps on till rad gets hot and fans cycle then shut off let cool down and recheck rad level should hold about 6 L of coolant if still haveing problems with heater gentaly losen the top heater hose so it leaks a bitt will alow air out [not runnig ]
