Everything posted by vamos
Update It was the Mass Airflow Sensor. I believe you hit the nail on the head Fairtax4me about it being broken solder connections inside the housing. Never did give me a fault code though. Picked up a MAF off Ebay for $17 ( out of curiosity I asked a suby dealer how much ... $823!!! ). No problems since I replaced it. Thanks to everyone who contributed
Thanks for joining in with your suggestions but I no longer have an air pocket in the heater core or anywhere else .. the gurgle is gone (read my update a few posts back). I did actually read of the vacuum method to suck the coolant into the block, also had what I thought was a good idea of taking the radiator bleed plug out then attaching a pressure tester to the radiator fill point and forcing the air out along with a lot of coolant but never got around to this. I actually gave up and was learning to live with the sound until my mechanic told me to just reverse the heater hoses where they go into the block. Did this and it worked.
OK, so here's an update. A few days ago, I take the car in to have the timing belt done, plugs, leads and fuel filter. So that gets done and on picking up the car I make a casual remark about the water gurgle about how I have been having a hell of a time trying to burp the air out of the heater core. He says "oh yeah, I did hear that when I took it for a drive, you know what you should do ... swap the two hoses around where they connect to the engine and then have another go at burping it again." I thought can't hurt to try, so next day when the ball and chain goes to visit her sister, I'm out there like a flash spill free funnel and screwdriver in hand. Unscrew the clamps on both hoses and swap them over. Was quick to do and I didn't lose much coolant. Spill free funnel on, coolant in, start car and wait for t.stat to open. All went well and the result ....GURGLE GONE. I'm beating my chest and swinging through the trees again. Happy Ending. P.S. The mechanic mentioned that he tried this method on other cars and it worked so it isn't a subaru specific fix. Hope this helps others.
Update: Have the car back from the shop, new plugs, leads, fuel filter and timing belt done. Code was found which indicated the MAF sensor faulty. However, still unsure about this as I expect it would have thrown a code since I did unplug the MAF and run the engine. I realized later after picking up the car I should have mentioned this to the mechanic .. I forgot. Engine hasn't died since but there has been the odd moment of hesitation from the engine whilst driving. Looks as though I will be replacing the MAF sensor. Mechanic is looking around and will price a used one for me. Not too sure about that. As for the battery, had it checked out and it didn't have enough crank power left in it to turn the starter over so replaced it. Alternator checked out OK.
I did unplug the MAF as you suggested and whilst the engine idled OK as soon as I increased the revs the engine would nearly stall so did not bother to even try to drive it any distance. By the way the engine did die this time on a short drive and also lost power a couple of times but came back up before stalling. Another annoying problem has developed the last two mornings. Have to jump start the car, Turns over but battery goes dead after a few seconds. Funny thing is the multimeter shows the battery to have a full charge prior to turning the key. I'll get that checked out too.
Absolutely awesome information. Thanks Although from what you describe, you would think the problem would occur even on my short drives around town (10-12 miles at a time) which it never has. It's only been happening after a long drive and then getting caught up in traffic. I'll see if the mechanic can pick up a code when I give him the car next week.
Thanks for replying. Interestingly, I found this when searching the net for this same problem and look what came up:- We own a 1994 Subaru Legacy 250T station wagon. Over the past few weeks while driving along the engine cuts out. All the lights on the dashboard come on, and the power light flashes. You can then put the car in neutral or park and turn the engine on and it restarts without any problems. We have taken the car to our local mechanic and he ran the computer diagnostic on the car, but of course while the mechanic had the car the problem did not occur and he could not find any problems with the car.*** We have checked all the connections to the battery and any other electrical connections but cannot find anything loose. Have you any idea what may be causing this problem? Reply Hi, we contacted the Anything Electronic Co. and they advised that the problem could be a fault with the Airflow Meter. We took the car to the Subaru dealer and they put it on the analyser and it did report a possible problem with the airflow meter. We replaced the Airflow meter with a new part and have not had any problems since. So you may be right about the MAF sensor. Before I replace it, I have booked the car in to get a timing belt change done and will ask the mechanic to offer his advice and check it out. I also have new plugs, leads and fuel filter on the way from Amazon. Thanks again for your help.
Thanks Nipper. I have ordered a fuel filter, iridium plugs and leads from Amazon. Also because I have only had the car a few weeks and unsure when the timing belt was last done, I have booked it in. Getting the full treatment, belt, pumps, seals and idlers. Will be asking the mechanic to give his thoughts on my problem and check a few things.
Still waiting to receive new plugs, fuel filter and plug leads from Amazon ( i live in Australia). Meanwhile the engine cutting out just happened again. After a long drive I stopped for a few minutes to pick up a few groceries before heading home. Got in the car and within 30 seconds engine died, put the car in neutral whilst still moving and it started right up. A couple of miles later the engine nearly stalled and perked up but died later as I entered my driveway. I did have plenty of fuel in the tank. This problem only seems to occur after a long drive. I have checked my sensor connections but will wait and see what happens after I put in new plugs, etc.
Thanks John. No, I didn't because an earlier post did not mention this when they stated "THE RIGHT WAY" method!! I have however on previous attempts taken the bleed plug out and filled the radiator through it. Also, with using a spill free funnel. I have let the car run up to an hour venting out as much air as a could.
OK, had a go at doing it the proper way. here's what happened..... Drained radiator with cap off .... check Started car.....check Very slowly filled radiator .... check Waited for t-stat to open ....Did not happen What did happen is my fans came on and stayed on. The t-stat didn't open and the temperature started to go beyond the normal range so put the radiator cap on and went for a very short drive hoping this would open the t-stat. Temperature gauge went to the very top and no heat from the heater. Got back (only travelled a half mile). The water in the radiator was boiling and I started to hope I have'nt done any permanent head gasket damage. The other times I tried to bleed the air by putting the nose up on ramps, spill funnel, holding the revs up, etc The t-stat did open but never shifted any air from the heater core. This time by draining the radiator, the t-stat didn't open and gave me a scare when the temp gauge went ballistic and only cold air from the heater. So I left the car for 8-9 hours to get cold. Checked the coolant level and took the car for a drive. A short drive at first and when the temp gauge stayed at normal and the heater was blowing hot air I went for a longer drive (30 miles) really giving it a bit of a push. All was OK.. temp gauge just under half way, blowing good heat but the gurgling water from under the dash was still there. If anything sounded louder than before. After the drive, I checked the radiator cap and it was cool to the touch, the bottom radiator hose was cold although both top and bottom hoses felt like there was good pressure in them. I've had enough of a scare to give up on this for the time being. It's only noise and as the car is running OK who am i to keep poking at it. Since I have only had the car a month, I will soon be taking it to a Suby mechanic to have the timing belt changed along with the other bits and pieces and I will leave it to him to clear the air from the core. Interestingly, I met another Suby owner at the gas station and his Outback had the same gurgling noise. Perhaps it's just a quirk that some Subys' get an unmoveable air-lock in the heater core. Thanks everyone for your help. Beaten by a car, for what should be a simple fix. But what really irks me was my wife's last word on my attempt to fix this when she said "Just let the mechanic do it"... My manly gonads aren't swinging as they should be.. somehow I must redeem myself.
I know this is a well worn theme but I'm having no luck shifting the air out of the heater core in my 96 Legacy EJ22. Tried up on ramps, running the motor till the fans come on and thermostat opens, spill free funnel used. Reverse flushed the heater core plus coolant flush. Have pressure tested the system, all ok. Heater has great heat, not losing coolant. Still can't move the air. Here's what I'm thinking. Car up on ramps again. If a pressure tester is attached to the radiator neck and with the bleed plug off and the overflow hose crimped, would pressure once applied get to the heater core and displace the air or will the pressure be stopped by the closed thermostat (doing this on a cold engine)? Got to be a surefire way to move this annoying air and stop the very audible water noise. It's there all the time when driving.
Hi, I drive a 1996 legacy with 100,000 miles on the clock, EJ22 motor with auto transmission. Car was recently purchased from a dealer. Only had the car a week and whilst driving in traffic about 15-20 mph the engine just died and all instrument lights came on. Pulled the car over turned off ignition and turned the key and it started straight up again. Since there was a Suby dealer only a few miles away I drove over there and they checked the car but there were no fault codes. I was told the only way it would leave a code is if the engine died again and wouldn't start. Then I would need it towed to the shop. I drove home 60 miles without it happening again. Two weeks later same thing happened 3 times within 3-4 minutes. Each time just put it in neutral and restarted the car no problem. Again I was driving at a low speed in traffic. So did some research and thought maybe a dirty air flow sensor so cleaned the sensor with the CRC MAF spray and put in a new air cleaner. Engine has not died since (about a week ago) but yesterday driving on the freeway around 60 mph the engine started to die or miss as though it was starved of fuel for a couple of seconds. It hiccuped like this 2 or 3 times then was ok and I drove the 70 miles home without it happening again. Has anyone comes across this same problem or have any ideas where I should look next? Don't really want to replace good sensors if they don't need it. Thanks.
Thanks GD for the advice. I'll take the car to a shop to have a pressure test done. I haven't noticed any leaks and the coolant level is OK. As for the radiator it looks new. I recently bought the car and don't know the service history on it. Perhaps because it isn't holding pressure is why I have the air pockets making the rushing water sound under the dash. If you don't mind, would you know the correct procedure to bleed the air out of the cooling system. Is it better to leave the radiator cap on and remove the air vent plug only then start the car and let run? I have tried putting the car front end up on an incline and removing the radiator cap and running the engine until the fans come on but I still hear the noise under the dash whilst driving. Thanks again.
