7
Everything posted by turbosubarubrat
Pulled a 5 speed d/r saturday then steam power washed it. Has either 220k or 222k on it can't remember but it has been resealed at one point. Since it has black rtv sealer on it and the rear shaft has a new gasket Here she is plus a canopy i got for free awhile back.
87 gl-10 Rough Idle
turbosubarubrat replied to mm88swrt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If its rocking back and forth really hard the #2 and #4 injectors are plugged up so fuel cant go in at the right psi or they are on their way out soon. One of my ea81t's had the same problem where one injector went out and it was running on 3 cylinders. -
technical data of the engine EA81 1595cc
turbosubarubrat replied to canuantonio's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This might help you the ea71 is a 1600cc engine and the ea81 is a 1800cc engine. -
Sealed Beam to Halogen Headlight Swap
turbosubarubrat replied to edselehr's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's been going on and off craigslist for a couple months i've thought about getting it but don't want to deal with cutting up a car into 5 pieces just to get a single range 4wd transmission. If it was a dual range or a awd i would have been all over it and fitted it in my brat. -
If you get this and part it out i might buy the transmission. http://portland.craigslist.org/clc/cto/4480414670.html -
I do have the wiring with bulbs with both connectors. When do you want to come get them $20 for 2 sets 1 crack free and one cracked set. -
I have the corner lights if you don't have them I'm about 2 miles from you. Your probably the guy with the blue dl wagon off Compton right? -
Finally got the trim piece on. Sanded, primed, and painted again.
What Transmission did I just buy?
turbosubarubrat replied to spicypeanut's topic in Historic Subaru Forum: 50's thru 70's
Looks like a 4 speed d/r. -
How to open stuck door
turbosubarubrat replied to alaskaloyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You might get it open going old school with a coat hanger and time if if it turns out it's the only option besides cutting up the door up. If i were you i would take out the bottom portion of the rear seat and take off the door panel since it's easy to do but might be a challenge to get the bottom off. -
15's can fit without a lift and it has been done before you just need low profile tires.
Injector size for EA-81 MPFI
turbosubarubrat replied to Subwat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
EA82t's have 180-185cc injectors and so do EA81T's since they're the same -
Wouldn't that just change the firing order if he turns it far enough? So it could still be the cap not making good contact to the rotor on 1 of the 4 contacts or a bad wire even straight out of the box. If the coil was bad you wouldn't get spark to any cylinder or weak spark to all. If it was running on 2 i would say replace the ignition module but on 3 it 's probably a wire or cap.
incessant Y pipe rattle fix cost 20 cents
turbosubarubrat replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Tack the screws with a welder so you don't have to worry about them coming out. -
If it is spfi it could be a bad plug wire, spark plug, cap, stuck valve or valves not seating. If mpfi it could be any of those things plus a bad injector or bad connection to a injector.
Stock Subaru 360 vs. Monster 360
turbosubarubrat replied to 2stroketurbo's topic in Historic Subaru Forum: 50's thru 70's
Definitely need a video of it on a track when done. -
My new Project: Leone Turismo
turbosubarubrat replied to Lukas's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Coupe is looking good. It must be super fun to drive around and just cruse with. -
ea81 blower motor relay location?
turbosubarubrat replied to turbosubarubrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks i got the relay in today and now it works good. -
It could be both swap in the rear drive train (brakes, hubs, diff, drive line, axels, ect), transmission(4 or 5 speed), flywheel/clutch, and a piece of interior plus a hole in floor for 4wd shifter then you got your self a 4wd subaru wagon.
Did research on this but couldn't find anything really specific besides for ea82's and factory manual doesn't say were its located but says it has one. All i can find on my hatch is the turn signal relay, wiper relay, head light relay, and fuel control unit (little rectangle box mounted with the hood release). After i tore into the dash today to try and get it working so i have a heater if i ever need it but couldn't figure it out. Have power to both heater fuses on fuse box but don't have power to the fan switch, resistor, or blower motor. If i hook the blower up straight to the battery it turns on fine. Pics of location and advice very are appreciated.
