7
Everything posted by turbosubarubrat
EA81 - adding negative rear camber?
turbosubarubrat replied to musubk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My hatch has the same setup but i have a 6" lift and 1 1/2" rear wheel spacers. The wheel spacers made my track front and near perfectly the same. Rides great with new shocks, struts, and springs. Springs are a little stiff but rides way better than many lifted 4wds. -
If you already have or can get a fat case bell housing with a side mount starter then you can put in a ea81 or ea82 2wd 5 speed. I'm pretty sure you can swap in a lsd on a ea82 5 speed 2wd. I've seen it done on the 4wd and awd drives which have the same front half so i don't see a problem.
Your Best Guess On Value
turbosubarubrat replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You can find a nice one for around $2000 anymore than that look for one with a engine swap. -
I just used a deadblow, scrapper, and a pry bar that had a good angle to hit chips off with. Then shop vac'd the chips up as i went along. Just be glad it's a brat since the rest of the 2nd gens have 3 times as much. There are videos of people using dry ice with good results but it doesn't take too long to chip it out. To cut out the pan a sawzall would work fine and so would cut off disks with a grinder. With a zawzall you don't have to worry about etching glass.
The sound deadening traps moisture from leaky window seals and rusts the pan out on these. On my hatch i slowly took out the sound deadening, primed it, and used herculiner on the whole thing. If you wanted to add sound deadening i would get the foil sticky type to put in after bed lining the pan. When cutting the rust out go at least a inch past where the rust is at; i would go more to be safe. If you don't there is still rust in the metals pores and will show up again a couple months later.
Forgot to mention i was talking about the heater core here. I wouldn't be to concerned about the blower resistors as long as they all work. It's easy enough to change in the car if it starts to go out.
Broken bolt problem 1980 subaru brat
turbosubarubrat replied to skinny664521903's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's crappy set of taps if they strip in aluminum. If you didn't drill it out to far you could drill it out and tap it to a bigger size bolt or put in a helicoil. I had a ea81 someone f'd up the hole completely by drilling it out in 3 spots to get the bolt end out. It ended up making a hole about the size as a dime. I ended up cleaning the hole out really good and using alumiweld rod with a oxy propane setup to fill it in then used a die grinder to make the surface flat. -
Napa was the one of the few places i found that could actually get it and didn't charge hundreds for it. When i got mine 8 months back it was $72.
EA81 cranky pulley needed
turbosubarubrat replied to coronan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If i get time today i'll take a picture for you comparing the two different pulleys. -
The grooves are spaced out differently to accommodate the power steering, ac, water pump, and alternator. I've been playing with either putting on a ea81t or ea82 power steering pump on a regular ea81, but i'm going to have to make a bracket since the spacing is completely different. -
If its for your ea81t that crank pulley is turbo specific. -
Hot-Rodding a Brat in two stages - Suggestions?
turbosubarubrat replied to RAD's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If your stuck on carbs stick in a ej25 99 plus block with a set of phase 1 ej22 heads and delta cams. Use a early ford escort escort distributor and a 4 barrel carb or a set of weber down drafts. The 99 ej25 is 165hp stock add the 2.2 heads and cams is somewhere between 185-210hp fuel injected. -
Just got a Rx need more info
turbosubarubrat replied to SockRx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm out in Sandy OR so not to far. Don't have any thing planned tomorrow so if you wanted to pick one up you could. Sending you a pm. -
A key way came out of the transmission not sure where it came off though. It started turning all the way over once i put a clutch disk on it and it spit the key way out. I want $150 for the awd with diff lock and $250 for that d/r 4wd. I'll probably keep the rx trans since i have another one and i will eventually probably end up using it to build a custom transmission. -
1984 DL 1.8 emission question
turbosubarubrat replied to Jmpjose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Can't remember if there is anything else ran off that fuse but its only 2 electrical connectors. The ecm doesn't do anything since you took off the hitachi carb and most if not all the emissions equipment. I would just unbolt the ecm and get rid of it since it's just extra stuff you don't need. -
That one is a 85-86 3.7 dual range 4wd. You loose it being all wheel drive and having a center diff to lock. Same gear ratio so no need to change the rear diff. I have the same one that i would sell for less that has 158 thousand miles on it -
Unplug the ecm bolted to the steering column. No need for it anymore. -
Show more pics. I have a couple different transmissions you could swap in. I have a 3.7 d/r 4wd, 3.7 awd with diff lock, and a rx d/r awd with diff lock. I need to play with the rx transmission some since i just picked it up and it acts like its locking up when you turn the input shaft even in neutral. As in locking up i mean you can't turn the input shaft all the way be cause it hits something solid. I'll steam clean it and let you know. -
'92 Loyale 4x4: RWD, no FWD?
turbosubarubrat replied to mstr_pete's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes- 8 replies
- loyale
- transmission
(and 2 more)
Tagged with:
