dm88
About dm88
- Birthday 06/08/1988
Location
draper, utah
Occupation
student
Vehicles
98 outback limited
dm88's Achievements
Member (2/11)
0
So today my roommate drove it to work about 30 moles away all freeway. He said as soon as he got off it started to over heat but once he turned the ac on and got moving again it cooled back down. Then he pulled in to the parking lot at work and it started to overheat again. Do you think a little bit of air could be causing this much havoc? How would you recommend getting that little bit of air out? I don't really want to drain and refil unless I have to. Also I doubt combustion gasses are getting in because it wouldn't fluctuate like that wold it? Thanks again for all your help
ok so now i filled it up again using the proper procedure and im still over heating...it cant be the tstat because it doesnt have one. it cant be the hg because theyre new and plus i have non bubbles in the expansion tank. cant be the rad cap because its new. i dont get it.. this car is starting to really get on my nerves. i can hear bubbling from behind the dash and from the cooling system in the engine compartment once i turn it off and i pop the hood after it overheats. any ideas?
The only part I messed up was while torquing downt the drivers side head. I go the order down wrong but luckily I was only at the part where you torque down to 54ftlbs then back the bolts off 90 degrees twice. From that point on i followed the correct order. Plus I don't see any bubbles in the expansion tank and it's not spitting out the coolant like it did when the hg was bad so Im t asking a pretty educated guess that my mishap with the head bolts didn't affect it much.
Yup fans are working.. I took out the non Subaru t stat and it seems to be better (I just ripped off the spring and copper part and put in just the round part with the gasket...I know it sounds barbaric) ..I think I might still have some air because the temperature is fluctuating... Not nearly the spikes I used to get before the head gasket but it'll climb up to 2/3 then go back down. At least it's somewhat drivable for now. I'm going to wait for it to cool off then fill it with the heater on which I for to. That's probably why I could hear bubbling from behind the vents.
im pretty sure i got all the air out. i filled it to the top while it was at operating temp from both the cap side and the bleed side. now whats happening is it overheats when ic ome to a stop not while im moving rather quickly. i didnt get a rad cap because the dealer is closed but this makes me think its not the cap. what else could it be? i did put in a non subaru tstat but i tested it (in water on my stove) before i put it in.
So i put in a new head gasket because i was getting bubbles in the coolant. so i finished up and fired her up, filled her up with coolant and took it around the block. it overheated, luckily i was close to home so pulled back in to my garage and popped the hood and could see bubbles in the expansion tank....i nearly cried... then i though maybe its just air so i opened up the bleed screw and added a lot more coolant but i also noticed that the expansion tank filled up almost to the top (this was before i opened the bleed screw) then i heard the coolant getting sucked back in and the upper rad hose got really skinny. so i filled it up and took it around the block again and it made it twice around then it started to overheat again so i got back home and looked at the expansion tank and saw it was full to the top again after being empty again. once the car cools down it gets sucked back in. maybe a bad rad cap? THANKS
