12
mikaleda last won the day on November 12 2016
mikaleda had the most liked content!
About mikaleda
- Birthday 04/08/1992
Gender
Male
Location
priest lake, Idaho
Interests
Pulling wrenches, building Subarus
Occupation
mechanic
Ezboard Name
none
Referral
Someone told me about it when I sold them my Suzuki and told them I was buying a legacy :)
Biography
Been working on cars with my dad since I was old enough to know how to hold a wrench. Love working on my own cars and have never taken any of my cars to a mechanic.
Hoping to start a mobile mechanics business in the near future. -
Vehicles
2001 Impreza OBS, 2003 Silverado 1500, 84 F350
Recent Profile Visitors
3565 profile views
mikaleda's Achievements
Subaru Master (10/11)
236
Loyale 2.7 Turbo started following mikaleda
Just a little update on this thread. I ran across a problem on the Facebook side of the USMB. Short story the ecu in their 94 legacy was bad and causing a no start. I sent them a 1990 legacy ecu and the car would start, but would not run right. In short we found that the redtop injectors are slightly bigger and require slightly different flow rates than the gray, black tops. So to run redtops and get the best out of them you should swap to a plastic MAF sensor and ecu out of a 92-94 legacy that originally had redtop injectors.
My mom's old ej22 in her 1990 legacy auto sedan made it to 320k before it blew a head gasket, she owned it from 170k and had it for 14 years.
Update on my dewalt 20v max high impact gun. Still going g strong batteries still working perfectly. I had to pull and service the impact head (needed greasing) super simple and it's working as good as ever. I have yet to have it fail me, I'm quite impressed so far.
I just thought I would throw in an update. I just bought a gray pneumatic 3/8ths inch duo socket set with ratchet. I am seriously impressed, these are some of the nicest impact sockets I've seen and the 72 tooth count ratchet is a quite nice. Also my dewalt 1/2" impact is still going strong and has yet to let me down, I just recently had to pull the impact head and service it, that was quite easy. Another good cheap tool that I ran across recently is my 3 ton power zone Aluminum jack, it weighs in at 60 lbs and is quite sturdy and it was $150 on eBay.
So I've got a customer with an 05 ll bean outback and one of their oil cooler lines is rusting out. The Subaru dealer doesn't carry the pipe I need only the one on the front of the engine. The pipe I need runs by the exhaust up the back of the block into unknown territory. Its on the verge of failing and I'm not sure what to do, I really don't want a pull and save part because of how badly corodded this one is already.
That's probably one of the most common overheating issues with Subaru's that I've seen on the forums aside from headgaskets. I have tried many different tricks to fill the cooling system on a Subaru. What I've found is it takes patience,there is no quick easy way to fill a Subaru's cooling system. I will generally let them sit for a night and recheck the fluid before sending them out as well. Glad you found your problem and shared your experience with us.
- 35 replies
- Overheating
- coolant bubbling
(and 2 more)
Tagged with:
