12
Everything posted by mikaleda
Ya, I'm not a huge fan of K&N filters, their a pain to deal with. Once you clean them you have to wait for them to dry and apply the correct amount of oil. I've actually lost power with them when I first started using one just because I over oiled it. I've also heared of these filters causing MAF sensor issues, wich may not affect your model if its the MAP bases system. Long story short, unless you are really serious about getting the most out of your car, I wouldn't suggest a high performance filter like K&N
Sounds like dirty connectors were the problem. I've found that those connectors are problematic, a good cleaning of all your connectors might eliminate the rest of your issues. I would suggest getting some electrical cleaner instead of penetrant. Probably wouldn't hurt to check all you ground connections as well
Yes you can read codes on obd1 cars with a scanner if you buy a $1500 solarus scanner from snap-on, truly it just displays the codes it would normally blink out to you is all. Its really not worth buying a scanner cabable of doing this. Your plugs are probably just taped up into the harness. Here is a good link with pics that will help you find your connectors. http://www.surrealmirage.com/subaru/engine.html
I don't take anything loose other than the ball joint. I can do an Axel on one of these cars in 15 minuets with a lift and a good 1/2" impact. Once the ball joint is loose all you have to do is swing the hub out and you can pull the Axel from the hub then you can go on to the transmission side. I typicaly use a 36 inch craftsman prybar with my 3 pound estwing mininsledge, I've found that combination works most every time no matter how rusty. Some good penetrant helps as well, something better than WD40. I like pb blaster myself, but any good penetrant will help.
