12
Everything posted by mikaleda
Exactly why I wanted a spring loaded switch so you have to consciously move the switch to bypass the clutch. No different than hitting the clutch.I got the idea from the newer Toyotas that have an interlock button that does this. It sounds pretty straight forward, I will give it a shot. I'll post pics when I'm done.
I am tried of climbing in my car every time I want to start it espicially in the winter and I was thinking about wiring in a spring loaded toggle switch that could be used to manuely bypass the clutch switch. Then I can just reach inside the car hold the switch and start it. I know there is an interlock really and two confirmation switches on the clutch, I'm just not sure what I would have to do to make the switch bypass the clutch switches.
snow plow
mikaleda replied to RED DEVIL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Looks awesome -
Cool idea, make it into a submarine then it would be a SUBaru
Oil Filter
mikaleda replied to keith3267's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Still, you can tell by how the filters are assembled the differance is obvious. The quality of material is important. Also missing an o ring and being improperly assembled is two totally different things. If you had an oil filter blow apart than the bypass valve in that truck was malfunctioning. -
Oil Filter
Probably just one, fram really sucks. -
Oil Filter
( WARNING ) For You Fram Oil Filter Lover's.YouTu…: -
Oil Filter
I suggest you look up fram vs other filters like wix and Napa brand filters. You will never put another fram filter on your car. Buy yourself a quality filter stay away from fram. -
My check list when checking out a subie is in order. Tires: how well do they match are they all the same or mixed matched. This can tell you a lot about how well its been taken care of. CV axels: a simple visual inspection followed by a test drive inspection. Visual: look for tears in boots and or aged ready to crack open boots. Grb them and feel how flexible they are. Test drive, listen for clicking or grinding noises when turning. Tourque bind: warm it up drive it in tight circles both directions and see of you can feel it binding. Rust, undercarriage: check the bottom for rust holes and or really rusty crossmeber and components. Noises: check for CV axle clicking bearing noise Oh and most important of all check coolant level color and check for bubbles in the overflow after its been warmed up and driven a bit. (good sign of a bad head gasket).
