12
Everything posted by mikaleda
This is getting irritating, recently my oil consumption has shot way up. At 2000, miles I have gone through almost 3 quarts of oil and the oil is already dark. Obviously the oil on using is not of the quality I need for my usage. I'm going to try Napa's cheap oil, which I beleive is made by valvoline and see what happens. I also have been changing my oil at 2000 miles lately to clean out my HLAs wich seems to have worked.
This has seemed to work well on my car. I started changing my oil as soon as it started to darken About (2000 mi). I haven't heard a tick once and its been being started in -10 degree morning and it still sounded good an smooth right of the bat. Now I just need to figure out my oil consumption issue which seems to be getting worse.
That's why I said to rotate the tires, it will tell you if its tire related or not. And warped brakes can cause vibration at high speed, bit you would still feel it in the wheel when braking so next step is to verify rims and tires. Also tire technicians don't always catch everything so we can still safely assume its possible its tire related
Swapping the engine from a 90stick into a 99 auto is fairly straight forward. Your exhaust bolts right up. If you don't want a check engine light you want an egr intake, but any intake from 95-98 2.2 will work. Should plug right in no reason to swap the intake harness unless the harness on the new intake is damaged for some reason. Once you have the egr intake on you'll either have drill and tap a hole in the head for the egr pipe or do wt-dashs fix thats in here somewhere. He basically uses a couple brass adapters to hook up a 1/2 inch hose between the egr and the IAC inlet. I did this in my ej22 swap on my 99 outback and it works great.
A good intake cleaning may not be a bad idea either.
- 4 replies
- 1990 legacy no idle
- 1990 legacy
(and 5 more)
Tagged with:
Replace your MAF sensor get one from a low milage car at the junk yard then reset your codes and see what comes back. Knock sensors are easy to replace they are one wire and one bolt. Its under the intake on the drivers side rear of the block. The oxygen sensor code is more than likely caused by the failing MAF o would replace the MAF first and reset the codes and see what happens.
It sounds like you are finding your problems. I would say from the way you explain it that it very well could be a wheel bearing. Bearings on these cars can be tricky to diagnose. First try jacking the wheel up off the ground and see if there is any side to side play or noise when you spin it. If not then driving it for a while and feeling of your hub is getting hot or not will tell you as well.
It's fairly common for these older cars to have some delay in the awd engament. If you get a little front wheel slip before the rear engages that's normal, but if your front wheels slip continuously then there is a problem. More than likely it will be duty c or the clutch packs are shot in the center diff, those are the two most common problems. It wouldnt be a bad idea to get it up off the ground first and make sure that all the ujoints, CV axels. And hubs are connected tight and working properly, and they more than likely will be since rear end components usually go to around 300k miles depending on how hard its been used.
