12
Everything posted by mikaleda
I am in the middle of swapping a 96 ej22 into my new project a 99 OBW MT that had the god awful 2.5D in it. Everything is going well, I luckily had an egr 2.2 manifold to install on my motor so I can do the egr fix, but I have ran into a minor problem. The 96 motor is a phase 1 block and the transmission is a phase 2 block. The phase 1 transmission housing had a stud for the lower starter mount, but the phase 2 has a bolt going into the engine block. Now that I have the ej22 in I can't bolt down the lower starter bolt, do I need to drill and tap the block or tap the transmission housing or will it be okay with one bolt holding it in?
93 impreza
mikaleda replied to jelliff's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Nice glad you found the problem, good job. Always good to have info like this on the forum to help others with their diagnosis. -
There should be an adjustment at the clutch fork under the hood. If its a cable that is, I'm not sure of that year. If it is hydrolic there is no adjustment it probably needs to be bleed. If you aren't getting disengagement of the clutch a few inches above the floor adjustment is probably neccissary. I would start saving up for a new clutch though you are probably getting close to the end of the clutch life if your pedals that low.
Snow Tire
mikaleda replied to wblocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I love my hankook w409 winter I pikes. Factory siping good clean out and very sticky. They seem to wear a bit fast if you run them as an all season, bit I love the performance I get out of them
