12
Everything posted by mikaleda
http://www.powerprobe.com Its replaced my multi meter I still have a cheap one for certain things but a power probe III and up is way more useful than any meter I've ever tried including fluke
Never use any selant on headgaskets, they are always installed dry. Proper block prep and head resurfacing is key to getting the right seal and there is no subsititute
- 4 replies
- head gasket
- sealant
(and 3 more)
Tagged with:
It definitely seems to be some sort of grounding issue, I would check all grounding points under hood and under the dash.
Its rare, but I've seen it happen before A bad master cylinder leaking into the vaccume booster. All you need to do to verify if this is the problem would be to separate the master cylinder from the booster and look for fluid residue. Edit: just read you already did that, it is possible its leaking slow enough to suck it through the vac line and burn the fluid maybe?
There are a few differences on the front struts. There is a camber bolt on the strut to hub connection. It needs to be marked so you can re install the new strut with the correct camber. There is a reference notch on the strut and notches on the bolt. A paint pen works the best but sharpie works too. If its rusty enough the rust will leave a clear line where the old strut was positioned and you can use that to get the new strut lined up. The top hats turn and have a bearing in them that should be checked for slop, they rarely fail but its good practice. And I've found legacy's front springs can be a bear to compress all the way with normal coil spring compressors. I like to use this type since they are a bit more slimline and seem to work better. http://www.amazon.com/gp/aw/d/B000OUW7XE/ref=pd_aw_sim_sbs_263_1?ie=UTF8&dpID=41fmgtt-HgL&dpSrc=sims&preST=_AC_UL100_SR100%2C90_&refRID=0EFAEYKT7X2N0H3S6CYS I've used mine on several sets of Subaru struts using an impact they are definatly durable.
Load pro looks like a similar version of a power probe, but at a more reasonable price. I've been sold on power probe since the first time I used it though. It may be more but it will replace your multi meter. Auto ranging multi meter and it energizes circuits positive and negative at the push of a button. It can also power small motors like power windows and lots more. The built in flashlight is nice too. I'm not a salesman for them i just really love their product, it makes tracing electrical problems like this alot easier. Check them out http://www.powerprobe.com
- 28 replies
- ignition
- electrical
(and 3 more)
Tagged with:
I have changed several sets of shocks front and rear on subies from 90-99 and I've always been able to get them almost back to where they needed to be, but its not worth chancing a good set of tires. Put new good quality shocks in and you wont regret it. Unless its just a beater then I would throw a used set on get them as close as possible and call it good.
Okay I'm going to break this down #1 cold start idle fluctuation I would pull and clean idle air control valve. #2 heating control lights flickering. Common issue the solder points on the back of the HVAC controls crack and cause intermittent problems. #3 sounds like torque bind, search this forum for torque bind. First things I would do is make sure all four tires are matching size, tread wear and pattern. Check trans fluid level/condition Do you have any flashing lights?
Inspect the connecters to the motor by the battery I've accidently dislodged them before changing a battery. Its kind of a long shot, but is the only thing I can think of that would cause this issue.
